Results 1 to 9 of 9
Thread: hooking up a MAIN power switch? (key switch)
    Mar 2006
    columbia, mo
    anyone know where i can get one of these locally? (maybe autozone? i dont wanna pay the 7 bucks for shipping really)
    http://www.allelectronics.com/cgi-bi...EYSWITCH_.html
    whats the difference btw?
    anyways, i wanna wire up a master switch so that if my car needs to be serviced or something, instead of disconnecting wires (i hate quick disconnects, there not quick at all imo) i can just turn the switch to the off, and itll cut off the power
    so do i just connect it between the battery wire? or would i do it between the 12v signal wire?
    thanks
    Jan 2005
    You don't say what's local. Do you have a McMaster Carr near you? They have a huge variety of key switches (you have to search their site (http://www.mcmaster.com) as I can't directly link to a product category.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    autozone, pep girl, kragen all have them. Hell, check wally world, I think I saw one there too.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Or find an old computer with a keyboard lock. Should be the same thing.
    Tidder
    Try RevFE
    Mar 2006
    columbia, mo
    alright ill check autozone, so how do i hook it up? through the battery wire or the signal wire?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by Bboy_jon
    You shouldn't run all the power needed through a switch this small. Run the signal through it or use the switch to energize a heavy duty relay.
    ~Jimmy
    Mar 2006
    columbia, mo
    so would the signal still keep the amp off and stuff?
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    you would use the key switch to cut power in the signal wire to the various components. if you have the same signal wire for your amp, computer, etc, then run the wire through the switch and you will be all set.
    Mar 2006
    columbia, mo
    well ya the amp and everything is all connected to the computer
    man autozone nor walmart had the switch (autozone only had the big ignition switches)
    i just got one of those racing switches
    http://www.mnpctech.com/spdprtToggle.html
    so i just input the switch between the signal wire?
  1. PS2 used as case and working PS2 reset/eject switch as power and reset
    By Silentbob343 in forum Hardware Development
    Last Post: 09-07-2005, 10:09 AM
  2. Momemtary switch to cut all power to comp
    By PatO in forum Hardware Development
    Last Post: 04-19-2005, 06:17 PM
  3. Power inverter on/off switch question
    By Skipjacks in forum Power Supplies
    Last Post: 01-22-2005, 12:33 PM
  4. extending a ribon power switch...or where to get a new one
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-15-2001, 04:51 PM
  5. Saying goodbye to the power switch....
    By PatO in forum General Hardware Discussion
    Last Post: 04-20-2001, 12:52 PM
