Results 1 to 2 of 2
Thread: led question
    May 2002
    Florida
    led question
    I have what I believe to be a simple question, but I can't find an answer. Are
    automotive LEDs, like those used to replace dash lights, able to be adjusted for their brightness? Such as would the factory dimmer switch still work correctly?
    I seem to remember that LEDs need a minimum charge and have a constant brightness, but its been a long time since experimenting with them.
    Thanks.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Most dimable indicator lights in my (slim) experience have actually been bulbs, and not leds, altho they are the size of a led. I just took apart my head unit and discovered this, also discovered that the green coloring is just a plastic "slip cover" over the bulbs. And if you varried the current to a led in proportion to the power for the rest of the electrical system (instead of dirrrectly with) you could probably adjust the brightness.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
