Results 1 to 5 of 5
Thread: DDR PC2100 memory wont work?
    Falls Church, VA
    Man im confused. I have (4) 512 meg chips that i wanted to place in my PC. They state they are PC2100U, 512mb, ddr, 266, CL2, ECC. I have no idea what any of this means.
    Now I have 2 chips in my Dell PC right now. Both 256. There is no marking on them besides the manufacturer but when i pulled them out and physically looked at them, they were identical. The 512 chips fit in no problem but will not post. I get the 4 beeps from a dell motherboard. I tried reducing the chips to 2, then to 1, and then changing them to see if i had a bad chip. All of which had the same output.
    Basically i could use an explanation of what chips my Dell Dimension 4600 should use and why these wont work. What the hell am i gonna do with these chips now?
    Elsewhere
    http://www.crucial.com/store/listmfgr.asp?cat=RAM
    Plug in your make/model and it will give you Crucial part numbers and specifications for your setup.
    It would seem that you would want PC2700 (or faster) for optimal performance. The PC2100 might work, but I'd go with the better-performing RAM if at all possible... Better safe than sorry...
    How about the Wiki?
    Falls Church, VA
    time to sell some ram. Gracias!
    Jul 2006
    Quote Originally Posted by Will Albers
    How much for one stick?
    Newbie chanman's Avatar
    Jul 2006
    MN
    Most consumer Computers don't support ECC.
    ECC and Buffered RAM are usually only used on Server Racks.
    ECC is used to "correct errors" that happen when moving info in and out of RAM. In servers, errors can cause a system crash and a company may lose $$$ shutting down and restart the server. Buffered RAM hold info that is used alot to save time fetching it.
    usually when you have ECC, you have Buffered. Same thing with nonECC, you get unbuffered, which personal computers use.
    CarPC: 75% [ Parts: 100% | Software Install: 70% | Harware Install: 50% ]
    J7F2WE1G5 (VIA C7 1.5Ghz) Mobo |1GB DDR2 PC4200 Ram | 40GB 2.5" HDD | DVD\CD-RW Slot Load Optical Drive | M2-ATX PSU | Lilliput 619GL Touchscreen
  1. How to poop at work...
    By BoyNextDoor in forum Off Topic
    Last Post: 05-02-2006, 01:11 AM
  2. UK Seller 256MB & 1GB PC2100 266 DIMMS + Faulty Laptop
    By sama in forum Classified Archive
    Last Post: 03-21-2006, 05:58 AM
  3. FS: 20GB Laptop 2.5" HD & 512MB Ram
    By john94587 in forum Classified Archive
    Last Post: 02-07-2006, 04:15 AM
  4. FS: 512MB PC2700, PC2100 DDR Memory Desktop & Laptop Ram
    Last Post: 01-20-2006, 01:36 AM
  5. Frodo: Work Harder, Work Faster..
    By hevnsnt in forum FrodoPlayer
    Last Post: 09-24-2004, 04:09 PM
