Results 1 to 10 of 11
Thread: USB hub problem always disconnecting / connecting
    Low Bitrate fire's Avatar
    Oct 2005
    Melbourne, Australia
    Ok..
    ive got a USB problem..
    i have many devices that work on usb, and all seem to work fine when connected to the individual lines..
    however when connected to a USB hub, everything connected to the hub disconnects momentarily (and that sound comes up).. then it connects again (sound plays)...
    i thought it was the USB hub being a dodgy one, so i replaced the hub with a NEC 7 port USB 2.0 hub that is powered off the 5v rail from the computer molex plug....and guess what... i still get that disconnecting / connecting problem...
    the power supply is fine, and tested, works with other things too, so i dont think thats my problem.
    i recently re-wired all new usb lines in order to fix the problem, with no luck, they are 3m long (10 foot).. and they are shielded..
    i only use 3 things on the usb hub, and ive tried trial and error to find the device thats causing the problem.. and they all do...
    next.. i re-installed the computer, from fresh.. and installed nothing but these devices (usb remote, my k750 usb cable, usb thumb drive), plus the touch screen and road runner.. and i STILL get the problem!!!!
    i dont know what else to check..
    its either my motherboard?.. doubt it.. or windows xp sp2?....
    what can i try?
    Jun 2006
    I am having the same issues. I have a dlink 7port 5v hub. My hub will disconnect but won't reconnect unless i unplug and plug it back in. Not sure if this is a drivers problem or just a defective hub. If anyone knows, that would be great.
    Oct 2005
    that has just happened to me last night.. i got out of the car.. opened the boot and re-connected it.. it worked for 5 mins then began the disconnecting / connecting crap!
    ive tried a 4port hub, powered, unpowered, and now this NEC 7port
    how annoying is it!
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Old problem still not solved?
    Did you solve it?
    I have problems of a similar kind. I do not get connect/disconnect. I get "cannot start device" and "unknowndevice" depending on what hub I use. I have tried two identical ones, and a second type. None of the three gave me problem at home.
    All are active, and I supply them with 5V from a separate DCL11 DC/DC converter.
    [media]http://web.comhem.se/bengt-olof.swing/DVD_Power.jpg[/media]
    I have tried to use them as passive hubs without connecting the power and without grounding any part but no change.
    If I connect directly to my Commell LV-679D it works, even the USB DVD in the dash with a 5m USB wire. I run winXP.
    May 2006
    Calgary, Alberta
    Similar problem here but only since I relocated my computer from the back of my seat to the floor. Now when I play with the molex connector, I get the dinging noise and sometimes my screen will be a shade of pink or blue until I restart. I swapped my hard drive and touchscreen to their opposite molex connectors and it's only happened once since then......that was 2 weeks ago.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Sep 2005
    Stockholm, Sweden
    What connectors are you talking about, Maheriano? Power supply harness?
    Problem I see is USB only.
    I have a standard USB cable, I disconnect and insert the hub as a chain. Without hub it works, with hub inserted it doesn't. And I've tried 3 hubs and with or without external power to hub.
    Very strange---
    Variable Bitrate rcdash's Avatar
    Dec 2004
    My USB hub problems were solved by
    1. only using 4 port hubs (less power draw) and
    2. on standby, cutting both external AND bus power using a relay to intercept the power signal in the USB cable.
    3. having a single ground point for all power supplies (this takes some time to work out, but ground distribution blocks are very helpful)
    Sep 2005
    Stockholm, Sweden
    I think you are onto something with the power supply. I have 3 potential providers of 5V. The PC and the two DC/DC converters I have for the active hub's and the USB DVD drive that require 2A...
    I guess that is the only thing I can try. Investigate my wireing.
    Sep 2005
    Stockholm, Sweden
    Sorted the power. It turnes out that the problem relates to which USB port I use!
    I use all comell 679D eight USB ports, and some work fine with all hubs, some work without hub and some does not work with hub but with some devices!
    So nothing wrong with power, devices or hubs. And probalbly not driver. Its the mobo! (M2-ATX 160W power supply)
    I have emailed support. I'll let you know.
    Newbie machinehead79's Avatar
    Aug 2007
    Toronto
    Touchscreens arent meant to be connected to USB hubs. Buy a USB extension cable and connect from the USB root hub (from mobo).
  1. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 04:41 AM
  2. USB Hub disconnects..
    By bmbr in forum General Hardware Discussion
    Last Post: 05-12-2006, 05:38 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. Replies: 10
    Last Post: 03-03-2005, 09:02 AM
