Results 1 to 10 of 14
Thread: Help Me With Relays
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    Help Me With Relays
    alright.. so i jsut got back home... i go to my garage to see my baby...
    i get in.. notice it is kinda dark in there... i put my key in, press the clutch, and turn the key... and nothing happens.
    my carpc drained my battery.
    i expected it since ive been gone for a month, but then i fully charged the battery and the next day i go to drive it and its dead again.
    i know its the CarPC, i disconnect it manually (unplug the PS) and cover the end w/ eletrical tape so i dont blow up.. but i need an on off switch for not just the igintion wire... but the actual power wire.
    so... i decided to do that... now after bout 5 minutes of thinking about it.. i dont think a switch will be able to handle the load that the carPC has.. and thus i went to relays..
    now... heres my problem... i have no idea how to wire relays.
    so.. help...
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    Hey, all I did was I wired a switch for my master ignition wire. so I could by hand turn it off. But I don't think it's drain safe. I'll have to see myself if it's going to work.
    f1vlad.com/subaru/sparow
    ■■■■■■■■■■■■■■■■■■■■■ 80% progress ¤ (sold)
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Redian
    so.. help...
    EDIT: Small brain fart. You are draining the battery while the car is off. Hmmmmmm. What PS are you using/how are you powering your carPC. Are you using Hibernate/Standbuy/shutdown?
    Michael
    Feb 2006
    Nashua,NH
    Quote Originally Posted by Wiredwrx
    What PS are you using? You could always put a switch in the "accessory" line of the PS (or whatever you use to start the computer). That wire is low power, not like the main power form the battery. You do take it from the battery, right? Well, that is off track, sorry. Just put it in the switched/accessory wire, and you will be fine.
    Michael
    That's exactly how I am doing it.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    And don't forget, if you discharged your battery low enough, it's possible that it's internally damaged and won't hold a charge correctly again.
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by Jahntassa
    Not if its a deep cycle dry cell.
    If you are placing your system into standby then you know that 5v is always will be on. If you are placing the system into hybernation everything is off if you set your bios to S3 mode. Also opus new power supplies have the ability to disconect itself if the voltage in your vehicle drops below a certain level.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    So, which PS are you using, and are you using standby/hibernate/shutdown, or what
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by inniss777
    S3 (Suspend to RAM) applies to the suspend/sleep function. Hibernation is as good as shutting the pc off, as it dumps the memory contents to an image file on the HDD, and then shuts off. S3 basically shuts the machine off and uses just enough power to keep the ram refreshed so it can come back almost instantly.
    Oct 2003
    SOCAL
    I am using opus power supply. The power supply disconects at 10.5volts. Currently I am using standby set to S3 but I recommend hybernation.
    I have 2 deep cycle dry cell batteries with a isolater. The pc is connected to the 2nd battery. If that battery drains for some reason the main battery will still be charged to start the engine. When the engine is off the batteries separate from each other. When the engine is running they join as 1 and share the loads. This setup is because of my high current audio system.
  1. Control heat and A/C with phidgets relays
    By deus ex machina in forum General Hardware Discussion
    Last Post: 03-04-2006, 10:11 AM
  2. Help With Relays
    By ukchris in forum General Hardware Discussion
    Last Post: 08-23-2005, 02:52 PM
  3. Looking for a device to control 12v relays (USB Preferred)
    By s10blazed in forum Hardware Development
    Last Post: 05-10-2005, 03:34 PM
  4. Mounting high-amp relays
    By KyleYankan in forum Hardware Development
    Last Post: 04-10-2005, 12:42 AM
  5. relays & computers
    By marsjell in forum General Hardware Discussion
    Last Post: 05-06-2002, 03:36 PM
