Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: My Amp is Dimming
    FLAC Gutter's Avatar
    Dec 1999
    Casina, Italy
    My Amp is Dimming
    Ok, so I picked up a 400w Jensen 4 channel amp at Best Buy last night. It happened to be $80 instead of the normal $199. I hooked it up to my system and I could finally hear the music coming from my system. With all the knobs on the amp turned to minimum, I started raising the volume in my software. When it got to about 70 - 80 db (rough estimate), the amp started beeping and the lights on it dimmed in and out. I'm guessing that it's a power problem, but since I have zero experience with amps, I wanted to ask you guys. Should I run a seperate 10 gauge wire from the battery to the amp?
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    I will setup my system kinda like this:
    phat car = common ground
    ok, that many fuses is overkill, but helps trouble shooting..
    Oct 2001
    NYC
    yeah i told you... AVOID JENSEN AND JVC... jesus... if you dont want to listen, how will you ever learn anything?
    Constant Bitrate monger's Avatar
    Nov 1999
    Good ole Maine. Gotta love trees and deer.
    just a guess.....
    You said that you were turning up the volume with software. My guess is that you were feeding the amp with too much power in the LINE level inputs. Heres the solution, set your software volume in winamp to about 2/3 max. Set the main volume to about 1/3 to 1/2. THEN adjust your amp gains (shuold say level or something along those lines) until the speakers start to distort. Then turn the gain level down a few notches. This way your computer is not feeding the amp more power than it can handel on the imputs.
    Then again, how exactly are you powering this thing? What are you using for speakers? Are you using the POWERED output on your sound card?
    The above was just a guess as to what the problem was. A little more info would be helpfull.
    Monger
    ICQ-7207702
    UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
    Oct 2001
    NYC
    no, you want winamp turned up ALL the way... it will give you a cleaner signal.
    here are your problems:
    1) Jensen
    2) you need a direct fused line from the battery... at least 8 guage
    3) you need to quit being a cheap skate
    Dec 1999
    Casina, Italy
    First of all, Alives, STFU. Your opinion is no longer requested. You have my sincerest apologies that Jensen amps trouble you so. As I said in the other thread, I just needed a cheap way to amplify the sound coming from the soundcard. I'm not about to spend $200+ on an amp to power my stock speakers. Maybe if I had better speakers or actually gave a flying ****, I'd spend more.
    Prehaps therapy will help your need to crap on other people. Take your inferiority complex and bad attitude somewhere else.
    As for the amp, I fixed the problem. I ran 10 gauge wire from the battery and it doesn't dim anymore. It sounds great, and had my stock speakers rockin'.
    Oct 2001
    NYC
    sounds like my suggestions helped
    Apr 2001
    Here, There, Everywhere
    good to hear you fixed it.... I didnt realise that thick power wire would be THAT important.... now I know...
    Project - GAME OVER :(
    Oct 2001
    NYC
    low voltage high amperage... thats why they sell 4 guage and 0 guage...stuff is ridiculously thick
    Apr 2002
    moose jaw, sk
    depending on your sound card. my sound card starts to clip the output at 100%, i find that it stays clear up to about 80%
