Results 1 to 7 of 7
Thread: comp won't boot with USB to IDE dvd rom plugged in
    Jun 2006
    Upstate NY
    i just switched my dvd rom from IDE cable to USB-IDE adapter. the rom works fine with the adapter once in windows. however, i cannot boot with the rom plugged in. if the rom is plugged in via USB adapter when i attempt to boot, the comp will just hang on the VIA screen....then if i unplug the rom, it will continue to boot normally within 5 seconds. then if i plug it back in after it resumes the boot, the drive works fine. any ideas on what could be causing this? i tried google and searched here and only found one other person with the same problem, but no solution.
    VIA Epia M10k, M2 ATX PSU, Pioneer DVD slot load slim Writer, Lilliput 619, WD 3.5" 80Gb HDD, BU-353 w/iGuidance v.3
    Dash Fabrication 100%
    Computer Setup 100%
    Elsewhere
    Enter the BIOS setup and make certain that USB boot is disabled and that USB is not one of the options in your boot order.
    How about the Wiki?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I have a system with a VIA motherboard, and it hangs on BIOS if I have my Sony DVD burner hooked up (USB). I haven't tried what Darque suggested, but I know the only way I can boot is unplug it.
    Sounds like a glitch in VIA boards..
    Jun 2006
    Upstate NY
    i can't find any option to turn off USB boot...i have my boot sequence to just boot off the HD, eveything else is disabled...i've tried disabling several things that i tohught could be it but it still doesn't work...
    Computer Setup 100%
    Jun 2006
    Upstate NY
    guess i'll have to attempt a 35" IDE
    Computer Setup 100%
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    What else is plugged into your root hub? I had a similar problem with my m10k (this was a few years ago, and I'm strugling to remember the remedy), and I think it didn't like the drain I was putting on the root usb hub, so I switched a few of the high draw devices to a external powered hub, I think. I can't really remember, all I remember is i had similar problems, and then I fixed it, which isn't that helpful.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jun 2006
    Upstate NY
    thanks for the reply mp3dub. i've only got a mouse and a gps reciever hooked up to it along with the dvd drive. i ordered a 35" IDE cable i'll just have to hope that works for now. i'll update when i get it.
    Computer Setup 100%
  1. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 04:41 AM
  2. Slimline DVD + IDE adapter + IDE -> USB adapter = no drive in Windows?
    By WiCKeD 5.9L in forum General Hardware Discussion
    Last Post: 08-04-2005, 10:49 PM
  3. Slimline to IDE to USB (DVD)
    By mdray00 in forum Newbie
    Last Post: 02-23-2005, 11:09 AM
  4. usb dvd drive
    By skydiver in forum Hardware Development
    Last Post: 02-10-2005, 10:08 AM
  5. DVD Rom IDE to USB, 25ft. would it work?
    By mattress in forum General Hardware Discussion
    Last Post: 02-04-2005, 04:03 PM
