Results 1 to 9 of 9
Thread: great car pc out of the box
    Jan 2006
    New Jersey
    this seems like a great caar pc for those to lazy to build it urself
    http://www.buy.com/prod/Enano_DVDRW_...202862036.html
    i think the core duo motherboard and processor alone cost like 600
    Elsewhere
    It looks good.
    The only thing that I can't find anywhere is the power requirement.
    It's more than likely an external power-brick type of connector, so it's very likley that a regulator like one of the Carnetix units (likely, the P1900) will work well for this setup.
    How about the Wiki?
    Jan 2005
    It does look good. I note the following:
    1) It's smaller than a single-din slot!
    2) It's DVI video, so you'd need a DVI to VGA adaptor to use most touchscreens
    3) All expansion must be via USB (not an issue for most)
    Nice find.
    KevPriest
    Mar 2005
    It does look nice, but the problem I have is what heppens when the motherboard dies? That is why it is nice though more of a hassle and expensive to build your own, though it seems no one wants to get into the market seriously besides VIA at the moment.
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    Quote Originally Posted by kevpriest View Post
    Nice find.
    KevPriest
    1) true
    2) true
    3) not true, check the mobo, they have serial and parallel ports connectios on the mobo, just not on the outside of the comp
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by sxott View Post
    in terms of what?
    making mini-itx motherboards? or making mini-itx motherboards that have embedded processors?
    Jan Bennett
    Registered User
    Looks like a knock off Aopen mini pc
    http://minipc.aopen.com/Global/spec.htm
    Mar 2004
    Probably not a knock-off, but an OEM resale...
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by jmbickham View Post
    I don't care what it is, it is nice. Price is the only thing. But those who are willing to pay for a small setup, probably come to about 1/2 that price DIYing it. Add in advertising and profit, and it is not a total ripoff if you want a warranty, and don't want to build it yourself.
    Nice find.
    1.9in x 2.9in -- 47mm x 73mm
  1. Lilliput works on home pc but not car PC!!!!!!!!!!
    By lax4321 in forum LCD/Display
    Last Post: 02-24-2007, 06:24 PM
  2. Custom ignition/alarm/immobolizer system
    By PredatorCoder in forum Hardware Development
    Last Post: 04-07-2006, 05:42 PM
  3. Car pc works when engine off, but not on..
    By drewinstl in forum Power Supplies
    Last Post: 09-05-2005, 07:07 PM
  4. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
