Results 1 to 6 of 6
Thread: Pac AAI-NIS2 using a digital cable
    Newbie Hapyfishrmn's Avatar
    Jul 2006
    Central Illinois
    Hey all,
    I am still trying to learn what pieces to install in my in car setup. But I am going to use the Pac AAI-NIS2. I would like to run digital cables from my pc to the Pac AAI-NIS2, but it takes RCA input. So my question is:
    What to use to convert from the digital signal to the analog?
    Am I going about solving the problem correctly or is it overkill. I am not sure what soundcard I am going to go with I am thinking external so any suggestions would be appreciated.
    hap
    '04.5 Laser Red | 5AT Cp. | Aero, Navi, Prem, & Perf Pkg.
    Jul 2006
    Central Illinois
    Since no one has given any input what is the best way to go from a digital signal to a analog signal. I looked for a DAC converter, but they are very expensive so is my only solution is go from a PC-> Amp->Pac->Head Unit ??
    _
    Mar 2004
    Little Elm, Texas
    Why would you go from your PC to you amp then to the PAC then back to the HU?
    Typically, you would go
    PC> PAC> HU> AMP
    and, as such, is there a reason you are stuck on going optical?
    yes, you can get a cleaner signal, but I question the point if you're just going into a head unit....
    Jan Bennett
    Jul 2006
    Central Illinois
    Yeah I am just trying to keep the signal as free from noise as possible. Thats why I tried to go with a digital cable. I don't really know how much noise a analog signal would have.
    One thing is that I don't have a lot of room and I would like to keep everything tucked away, thats one reason I don't really want to go with an amp. I don't know much about them either so that probably doesn't help. Should I even go with an amp if so which one?
    _
    Mar 2004
    Little Elm, Texas
    I undestand wanting to keep the system free of noise. It's why I am running an optical cable in my car. From a sound card into an Alpine processor.
    With good RCAs and run properly, not much noise will be induced into an analog cable, but with a computer in the car, there's more chance of it.
    There aren't very many people who have a lot of room on here. In fact, if you had room, I'd say you were in the minority.
    I'm a bit confused how going with an amp will enable you to tuck things away and would make a difference since you don't have a whole lot of room.
    As for which amp?
    FAQ: What speakers/amps should I go with?
    Jan Bennett
    Jul 2006
    Central Illinois
    Quote Originally Posted by Hapyfishrmn View Post
    and I would like to keep everything tucked away, thats one reason I don't really want to go with an amp. ...
    I do not want to go to an amp unless its necessary. Thanks for link I'll check it out
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 04:45 PM
  3. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
  4. 1:1 Hirose Cable Group Buy!
    By claylong in forum Classified Archive
    Last Post: 08-31-2002, 03:55 PM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 09:29 AM
