Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Sound only coming from one port of the sound card.
    May 2006
    Calgary, Alberta
    I failed to realize this until just now, but there are 3 ports to the sound adapter on my motherboard and only 1 is working. I have the M10000 motherboard, using the onboard sound and it's the middle port that's providing sound right now. The top port doesn't do anything and the bottom port for the subwoofer isn't doing anything. I have the sound set up for 5.1 in the Control Panel of Windows.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    What's the source for the audio? Is it just stereo (i.e., front left and front right)?
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    May 2006
    Calgary, Alberta
    Well the M10000 has 3 ports, a stereo front, a stereo rear, and a microphone. So that's left/right for front, left/right for rear, and the microphone can be changed to a subwoofer.
    I'm sending audio out of the 2 stereo jacks into a 4 channel amp, and out of the mono jack to a mono amp for the sub.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Newbie getyours_2006's Avatar
    Jul 2006
    Netherlands
    You have to install the soundcard drivers after that you will be able to enable 5.1 compatibility on the property tab of your soundcard properties
    May 2006
    Calgary, Alberta
    Quote Originally Posted by getyours_2006 View Post
    UWAHHHHHH? Where do I find the soundcard properties? In the system tray? I thought I did install the drivers for the motherboard, almost positive I did. I'll check for that properties tab and see if I can change it. Thanks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Quote Originally Posted by Maheriano View Post
    I believe it will be sub and centre channel. Remember it's a 5.1 configuration coming from the OB AC 97 codec, not 4.1
    You'll have to grab the sub portion of that output and leave the centre channel behind if you're not intending to use the centre channel.
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
    May 2006
    Calgary, Alberta
    And I imagine that option will be in the sound card configuration?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    I read other threads where they're talking about line converters, and the center/subwoofer splitting, and power issues. Can I even do what I'm trying to do with what I have?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Jul 2006
    I believe you're still on the right track. Remember that each of one of those MB outs has 2 signals in it. Your taking each of those outs and sending them to their respective places on the 4 ch amp - front L/R and Rear L/R. The 3rd out having the centre and sub signals will have to be distinguished/separted. Meaning you have to find the sub signal from that 2 signal line and send it to the sub amp. The centre channel signal will just not be utilized - right? And that's OK. As far as determining which is sub signal and which is centre signal from that line. I think I'd have to experiment with the amp output to determine if the input signal is full range (centre) or low(sub). You won't kill the sub speaker if the centre channel signal was sent through if the volume isn't cranked up. You're doing it right so far. Don't doubt yourself.
    John
    May 2006
    Calgary, Alberta
    UPDATE
    I looked everywhere for a GUI to configure the sound card, it doesn't exist. All I have is the sound option in the Control Panel and I have the sound set to 5.1 there. That obviously isn't working. But when I opened the volume settings, and went into advanced, I enabled the Smart 5.1 Surround and my sub thumped for a half second. But when playing music, no thump. I turn the Smart 5.1 on and off and it thumps again, but it won't actually thump for music.
    The amp gain is up, the remote bass knob is up, the subwoofer volume in the computer is up, and the bass in Road Runner is up. Still no bass. But when I remove the 1/8 adapter from the mic slot of the computer sound port, the sub thumps as the plug is exiting and entering. Not thumps, but makes thumping noises. This is all while music is not playing.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 08-26-2011, 09:30 PM
  2. the ever popular sound card problem....
    Last Post: 12-15-2004, 03:01 PM
  3. Any opinions on the Phillips Aurillium external sound card?
    By UMM in forum General Hardware Discussion
    Last Post: 02-27-2004, 04:39 PM
  4. rca sound card
    By Sway in forum General Hardware Discussion
    Last Post: 02-01-2004, 11:47 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
