Results 1 to 4 of 4
Thread: Via Dual Slot PCI Riser - Manual?
    Aug 2004
    Bundaberg QLD AU
    I have recently purchased a fair few components to start building my carputer (Via M10000, PCI WiFi Card, Via Dual Slot PCI Riser, M1-ATX)
    Anyway the question I'd like to ask is does anyone know where i can get the manual for the Via Dual Slot PCI Riser (EXT-PCI Rev:B)?
    The reason I'm looking for the manual is, it has jumpers on the riser board and i'm not sure what they set...
    Also I'd like to know if the riser board can be inserted so that the slots face back over the top of the motherboard? Or does it have to face away from the motherboard?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    well, the jumpers i cant help you with
    but if the pci connectors are on both sides (doubt it) then it doesnt matter which way you put it, but i doubt that the pci connections are on both sides
    Aug 2004
    Bundaberg QLD AU
    no there isn't pci connectors on both sides... both are on one side... but it the riser will plug in either way... so i was wondering if you had to adjust the jumpers to set which way you want to face it...?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    most pci cards can fit in both ways, doesnt mean they'll work
    and most setups need the pci cards sitting over the mobo, so i doubt you can have it so the cards are opposite the mobo
  1. Replies: 0
    Last Post: 06-13-2006, 07:12 PM
  2. Two slot riser for MB850/890 boards?
    By amthar in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:42 AM
  3. 2 EPIA 5000 MINI-ITX Complete Systems CF, PSU, PCI Riser, Case
    By lilkeeney in forum Classified Archive
    Last Post: 08-21-2005, 05:43 AM
  4. PCI slot extension
    By alienjj in forum General Hardware Discussion
    Last Post: 02-08-2004, 02:35 PM
  5. Cant find the correct PCI riser card
    By -al- in forum General Hardware Discussion
    Last Post: 10-24-2003, 02:34 PM
