Results 1 to 4 of 4
Thread: 2.5" HD + 40 wire cable = Ultra ATA/33?
    Newbie Snoobaru's Avatar
    Aug 2006
    Before winter starts, I plan on replacing my CarPC's 3.5" 40 gig HD with one of Seagate's "Extreme Environment" series 2.5" HDs since I know for a fact that my current HD can't take the cold very well at all.
    These HDs have an Ultra ATA/100 interface and run at 5400 RPM. My motherboard is a VIA SP13k, so the IDE interfaces are capable of Ultra ATA/133. The problem is that the only cable that I have that converts between 3.5" 40 pin to 2.5" 44 pin is a 40 conductor cable, similar to this:
    http://store.mp3car.com/ProductDetai...Code=ADT%2D007
    If I remember correctly, if you use a 40 (rather than 80) conductor cable on devices that are capable of ATA/66 or higher, they will drop down to ATA/33 speeds. Won't this greatly increase my times coming out of hibernation?
    If that is the case, will this adapter,
    http://store.mp3car.com/ProductDetai...Code=ADT%2D001
    when used in conjunction with an 80 conductor ribbon cable allow the new 2.5" HD to run at ATA/100 speeds?
    Keith
    Maximum Bitrate DeltaFX's Avatar
    France
    Short answer : Yes. Have a look in your bios too, just to make sure things are as expected.
    Now Galileo is real. Muhahahahaha :p
    Aug 2006
    Is that "Yes" in response to my first question (I'll have greatly increased times out of hibernation), or to my second question (that particular adapter will allow the new hard drive to operate at full speed), or possibly to both my questions?
    Thanks for the response. I just need a slight clarification.
    Keith
    France
    Nope, I anwered your ATA100 concern. Of course, if the puter can acces Hdd faster, any action involving hdd should be done faster.
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 01:55 AM
  2. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  3. Can I Splice Wire Into An IDE Cable?
    By TimStark in forum General Hardware Discussion
    Last Post: 11-19-2004, 05:17 AM
  4. To extend my 5 wire touchscreen cable or not?
    By e_fractal in forum General Hardware Discussion
    Last Post: 11-07-2003, 04:31 PM
  5. FS: 15' feet of 80 wire IDE cable. Great for DVD-ROM's.
    By LESLIEx317537 in forum Classified Archive
    Last Post: 01-26-2003, 11:53 PM
