Results 1 to 10 of 18
Thread: AUX input on Mercedes
    May 2002
    New York
    Question AUX input on Mercedes
    Hi all,
    I own a 2000 S500. I am trying to connect an iPod. Right now I am using a cassette adapter to play. The sound is good but the deck has a door that does not close completely because of the wire sticking out.
    There has got to be a better way! No one seems to know or want to touch it because the system is all fiber optic. I'd like to make an AUX connection and run the wire to one of the storage bins and hook the iPod into it from there.
    ANY ideas or opinions appreciated.
    Mar 2001
    Cincinnati, OH USA
    You can always try an FM modulator. It connects directly to your antenna input, and brodcasts the signal to a FM frequency. It will give you much better sound quality than a tape adapter.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    Mar 2002
    FM removes the low and high ends of the audio spectrum for some reason...if you can live without those then do the FM modulator thing.....
    Mar 2001
    Cincinnati, OH USA
    That may be true for open air FM, but I get more lows and highs with the FM Modulator + computer, than I get from my CD's in the car.
    Mar 2002
    i think i may be confused..
    you state that the FM modulator + computer combo produces more lows and highs than a CD?
    MP3s (I am assuming this is what you play through the PCU) use lossy compression, also in FM there is loss.
    It makes no sense that you would get more lows and highs via this combo than a store purchased CD which makes use of all audible frequencies (20-20,000Khz).
    (unless you have a low quality CD Player)
    Please clear this up for me.
    May 2002
    New York
    The modulator is still not the most ideal situation because of the output quality. What I really want is an AUX input. I'd even disconnect the CD changer if I could convert it.
    But if I cannot do that, any suggestions on a good FM Modulator?
    Mar 2001
    Cincinnati, OH USA
    In my car it certainly does! All I know is that it sounds better than any CD I have played due to the fact that the audio signal is amplified by the soundcard and I have more sound control via the computer (Winamp - EQ, DFX Soundcard - Environmentals, Bass & Treble adjustment).
    MBFiend - It is hard to recommend a FM Mod since some work better in some cars than others. I think some people went over this before, try searching the forum.
    May 2001
    Cincinnati, Ohio
    You say its all fiber optic. Does the stereo system have a fiber optic input? If so, RadioShack sells a analog to digital converter for $50 that will convert standard RCA audio to PCM coax and fiber optic digital signals.
    May 2002
    New York
    That's what I am trying to find out. I cannot find it and the dealer is no help. A couple of friends that do car installs either do not know or don't want to go near it because it is all fiber.
    Jun 2004
    tape adapter solution
    I have the same problem in my benz. The factory system is just not very easily modified, or added on to. I ended up using a tape adapter and running the wire out the back of the head unit. I connected my aux RCA inputs to that wire behind the head unit. Now the door stays shut, and there are no visible wires hanging out anywhere; everything is run behind the scenes. The quality is comparable to the CD changer.
    Kevyn
