Results 1 to 7 of 7
Thread: 3.2 Intel/micro atx mobo
    Aug 2006
    Is it safe to put a computer in the car with a 3.2 intel celeron D and 1 gig RAM on it? I am trying to decide between using an old laptop or building my own . I prefer a micro atx instead of a itx board because it is cheaper and more options. My concerns are power and heat, I plan on putting it under my seat (Honda CRV) in a custom case. Can ayone give me their input or suggestions?
    With a Micro ATX setup, what are my best options for power? Opus?
    Thanks guys!
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    umm, ur probably gonna get flamed for this.. (but not by me )
    power? get a big enough inverter and you'll be fine, heat? with that processor your probably gonna get a lot of heat, and i dont think you'll be able to cool it very well in a case that fits under your seat
    if you want suggestions or ideas, i'd strongly recommend searching, or looking in the worklog/show your ride sections
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    dont go the inverter way.. is a poor mans fix to be honest... it uses lots more power and you can also if you buy a cheap one which isnt a true sign invertor cause damage and at best get interferance in your sound.. I do think however the 3.2 celeron might be a bit much just to run mp3's on etc.. I would be tempt to look at there power rating.. ie how many watts they draw as a cpu.. some are alot lower than others... I would prob go for a M2 DC-DC PSU which also has a built in shutdown controller, something else which you dont get with an invertor. There are lots of F.A.Q's about this and that.. have a search around the forums, its more a case that only you can decide in the end whats good for you rather than people telling you.. it all depends on your needs and your budget and your car..
    hope some of this info helps
    Steve
    Feb 2004
    Manchester
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by CdRsKuLL View Post
    this is what i meant, with that processor could be more than what the sdc's can handle
    well, with mobo, processor, hd's, fans, screens and whatever
    granted he could just get 2 sdc's connected together, but, inverter is easier for a lot of people :T
    Elsewhere
    Quote Originally Posted by TheTreeHouse View Post
    This thread wil help you determine a suitable power supply and/or what hardware you could use with a specific power supply: FAQ: Will <insert PSU model> Power Supply work with my system?
    I agree with CdRsKull in that an inverter is a half-ased solution. A couple years ago when there werent' as many DC-DC PSU options available, it was the only viable method for powering systems more powerful than Via's EPIA motherboards based ont he C3 CPU. Now that there are better DC-DC PSUs on the market, only the most power-hungry setups require an inverter.
    The CPU manufacturers (Intel & AMD) are also producing more & more low-power CPUs, making the need to install a power-gobbling system a foolish venture anymore.
    How about the Wiki?
    Apr 2005
    Dublin, Ireland
    I don't agree that putting a high power system is a waste, i have a PIII 1GHz System, unfortunatly this system is will not do standby, also i have to upgrade it to decent video and USB2.0 and a new sound card, all had to be Low Profile and cost more than what i could have a got a 2.5GHz P4 from Ebay for a Spare MB i have, also ram for that MB cost me 20euros from ebay also.
    I like my music asap for the long drive to work. Its no good to me if by the time im leaving the estate its only starting then as i only drive 5 mins to work, i believe with Frontends getting more complex like Centrefuse as an example a high power system is an advatage, also the fact that a lot of us work in IT and can gain access to the parts for near nothing is another big factor.
    The only part that will cost me any real amount is the Opus 250 and until thats fully released il work on my new MDF Case :-)
    This new system will cost me about 300euro for a big upgrade, far less than the 300euro + cpu's people are putting into there cars.
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
  1. How to use a standard atx ps on a compaq mobo
    By tastyratz in forum Power Supplies
    Last Post: 01-07-2010, 09:02 AM
  2. Opus 150w Mini ATX 6 pin mobo power ??????
    By Impalaman in forum Power Supplies
    Last Post: 02-04-2005, 11:54 AM
  3. argh. intel p4 3.2 ghz d875pbz mobo
    By Nav_Attack in forum General MP3Car Discussion
    Last Post: 11-01-2004, 03:16 PM
  4. full ATX mobo and req. power
    By fishy in forum Power Supplies
    Last Post: 10-13-2004, 01:53 AM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 09:00 PM
