Results 1 to 5 of 5
Thread: CarPC with Vonage
    Newbie R A Rover's Avatar
    Aug 2006
    Santa Monica, CA
    CarPC with Vonage
    Hey Guys,
    I'm a total n00b so if you've all already seen this(and I haven't come across it yet) then sorry for the re-post. But I thought this was pretty slick.
    http://www.vonage.com/device.php?type=VPHONE
    Later,
    John
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Its gona be hard/ expensive to get a internet connection fast enough and stable enough to support that. and the latency may be to high...
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Aug 2006
    Santa Monica, CA
    True, but it gives me a glimmer of hope for the future. More toys! Actually, I almost never use the phone. I know how can I call myself an Angelino, right. Most of my "phone calls" are on my home PC using Xfire, Hamachi or TeamSpeak(for free.)
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I think at the minimum, or at least the lowest 'quality setting', Vonage needs at least 90 kbps
    you might have more luck trying a diferent VOIP provider, i have noticed that vonage requires a lot more bandwidth for clear calls then the VOIP provider i use for my business.
    I was runing voicepulse for 2 years for my business with no problems and then got vonage for our home lineand it sounded horrible they both are on the same internet, i had to install a QOS router on my network to get vonage to work.
    you could even run your own PBX system and you can then play with the codecs so you can lower the bandwidth usage...
    I use Connect.Voicepulse.com for the VOIP line, (cheaper then vonage)
    and then i have a P3 555 running TrixBox.org Asterisk PBX.
    1990 Jeep Cherokee
  1. carpc with name brand monitor
    By fasteddie in forum Input Devices
    Last Post: 08-25-2006, 07:09 AM
  2. muting head unit audio when carPC outputs audio
    By augieman in forum General Hardware Discussion
    Last Post: 04-18-2006, 07:35 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  4. Replies: 33
    Last Post: 09-01-2005, 04:14 PM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 11:27 AM
