Results 1 to 8 of 8
Thread: Audigy 2 ZS PCMCIA Card Problems
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    So, I wanted to switch to a PCMCIA card for my sound instead of the USB I was using.
    I put the card in, turn on the computer, when it boots, I load the drivers. It asks me if I want to restart, I don't. Everything works great. Sound comes from the card, and it sounds good.
    Then, I reboot, and it hangs on boot when it gets to the windows screen. The actual windows desktop, I mean.
    I shut off the computer, unplug the card, and it boots fine.
    I shut it off, and pllug the card back in, it hangs on windows desktop again.
    By the way, Ctrl+Alt+Del won't even work, it's completely frozen.
    I unplug the card, it boots fine. I remove the drivers, power down, plug the card in, and it boots fine. I install the drivers, and then it won't boot.
    So, final result: it boots with the card, but no drivers. It boots with the drivers, but no card. However, card+drivers equals frozen on windows desktop.
    These are the latest drivers, DL'd from the Creative site.
    Any ideas?
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I'd check to see if Creative hosts some forums (many companies do) and see if anyone is having similar problems.
    Constant Bitrate KaBoOoM's Avatar
    Oct 2005
    Portland, Oregon
    My only suggesiton would to download the previous (not the newest) drivers for it. That has solved some other devices problems for me in the past, not one like this, but might as well try it until you get more information.
    I'm hungry
    Sep 2005
    Bellevue, NE
    Well, I tried the KX Project drivers, and the same thing happened. I think it might be a bad card, I will be taking it back and exchanging it soon
    Core Duo CarPC
    CarDomain page
    Newbie krustydawg's Avatar
    Apr 2005
    Just so you know, this card is is known for have compatability issues with some PCMCIA cardbus chipsets, there is a list I belive on the creative site that tells you what chipsets it works on
    Krusty
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Also, check if you have enough power available from you psu... The initialization + windows booting (hdd + cpu activity) at the same time yould be just too much.
    What if you disable the card (in device manager) before rebooting?
    Good luck!
    _
    Mar 2004
    Little Elm, Texas
    Which mobo are you using?
    Jan Bennett
    Sep 2005
    Bellevue, NE
    I'm using the LV-673.
    I'll check on th elist of compatibility, and also see about the power issue.
    Thanks for the ideas!
    Dave
    Core Duo CarPC
    CarDomain page
  1. Do you get good reception with PCMCIA card in trunk?
    By S4Per in forum Wireless Communications
    Last Post: 08-31-2006, 01:34 AM
  2. Wanted: BU-303, Audigy PCMCIA, D3 USA Maps
    By DiNASTY in forum Classified Archive
    Last Post: 03-24-2005, 09:20 AM
  3. Dual Monitors/vid card problems
    By bosstone74 in forum LCD/Display
    Last Post: 09-07-2003, 03:00 PM
  4. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
  5. pcmcia card reader and pcmcia modem problem
    By dekodan in forum General Hardware Discussion
    Last Post: 05-24-2001, 01:04 AM
