Results 1 to 6 of 6
Thread: Biostar M7NCG 400 v7.2 with SATA PCI Controller Card
    Newbie msjonker's Avatar
    May 2006
    Indiana
    Question Biostar M7NCG 400 v7.2 with SATA PCI Controller Card
    Hi everyone,
    I recently purchased a Biostar M7NCG 400 v7.2 motherboard and am trying to use it with a Rosewill RC-201 SATA PCI controller card, since there is no onboard SATA support. I am using a Hitachi SATA 2.5" notebook HD that I was able to use with no problems on an MSI nForce2 motherboard with builtin SATA support. When i try to install Windows XP on it with the M7NCG, it just sits at the "Setup is inspecting your computer’s hardware configuration" but does not technically freeze, as pushing CTRL+ALT+DEL still works and the Num Lock key still functions. Setup starts normally when the HD is disconnected from the SATA card.
    This is a popular MB on this forum because of its Athlon XP-M capabilities and I am wondering if anyone else has had this problem and how they resolved it.
    Thanks!
    Low Bitrate sedtc's Avatar
    Jul 2006
    tally-ho, fl
    because this board does not support SATA, you will have a hard time installing onto an SATA drive due to a driver issue. as i'm sure you have already discovered, this board does not like the default (or detected settings) in the bios and requires the proper settings for a successful xp install. this board gave me a hell of a time when i tried to install windows using components that the specs claimed to support and came dangerously close to a "chance" encounter with a wall. while on my personal quest for answers, i encountered individuals who also suffered a similar plight as you. i faintly remember something about this board requiring you to install a driver for the SATA support via a 3.5" floppy before the board will properly recognize the hard drive. hate to be the bearer of bad news but you may be better served using an old EIDE drive for your OS. if your search here (which i assume you did before posting) came up null, might i suggest searching the web for more answers. this board is also popular in the HTPC and silent pc crowds, it was on one of those forums that i first read about similar problems associated with this board and the SATA drivers.
    on a side note, i hope that you are using ddr 333 (pc 2700) ram (especially if you are using the nvidia igp) and have all the correct settings for the memory and processor in the bios. the MCNCG is one mother of a board to work with out of the box. sorry i can't offer you more assistance.
    best of luck
    sedtc
    May 2006
    Indiana
    Thanks for your reply.
    All the hardware (with the exception of the SATA card) I'm using with this board was used successfully on an MSI board with the nForce2 chipset and had no problems. The memory works and Windows installs normally using an IDE hard drive connected to the onboard controller.
    I've read several posts about needing to press F6 when Windows Setup starts in order to load the drivers for the controller, but unfortunately, my install doesn't get this far as it gets stuck at the screen right before the blue Windows Setup screen. I think my only option is to install Windows onto the SATA drive using another computer and then attach it back to the Biostar and see if it boots up, as I really don't know of any other option. I've tried practically every change in the BIOS I can think of relating to this, but to no avail.
    I've searched this forum and Google, but still haven't found a solution to this problem. Its got me stumped.
    Jul 2006
    tally-ho, fl
    your problem is bios related, it sounds to me like the board does not see your pci controller and is looking for an ide device. check in the boot manager (IIRC, press F9 after you turn on your system to get to the boot manager), you may need to set the PCI device to boot after your cd drive (if this is an option), also check the bios settings for the boot devices and boot priority. i wouldn't try loading xp on another machine because you will encounter driver issues when you try to use the hard drive on the biostar board. aside from the issues with different board specific drivers, when you connect the drive to the controller, the board still won't recognize it. your problem is getting the board to see the device attached to the pci slot.
    Maximum Bitrate DeltaFX's Avatar
    France
    Dunno the bios of that board, but you may have something like
    1st boot device : Fdd
    2nd boot device: Hdd0
    3rd boot device : CD-ROM
    Boot other device (than the 3 listed previously) : enabled/disabled
    is the " boot other device" enabled ?
    Now Galileo is real. Muhahahahaha :p
    May 2006
    Indiana
    Quote Originally Posted by sedtc View Post
    I think that it might see the device, but there may be some sort of conflict with the IDE controller or something. I'm really not sure. When the board posts, the SATA card displays the hard drive that is connected, so it would seem that it is being recognized. I can't totally disable the IDE controller because I am installing from a DVD drive attached to it.
    I was thinking of just getting the base Windows setup on the hard drive by using another computer (all the stuff that happens before the reboot happens). I'm thinking that at that point, drivers won't be an issue, because it won't have actually installed Windows yet. Then, move the hard drive to the Biostar to do the actual Windows install.
    Quote Originally Posted by DeltaFX View Post
    Yep, I have "Boot Other Device" enabled.
    Thanks for your help!
  1. FS: Biostar M7NCG 400, Athlon XP-M 2200+ (35W), Opus 150W
    By migel628 in forum Classified Archive
    Last Post: 09-08-2005, 02:06 PM
  2. Case for Biostar M7NCG 400 and OPUS 150
    By kevlar in forum General Hardware Discussion
    Last Post: 06-02-2005, 11:58 AM
  3. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 08:51 AM
  4. New powersupply! Question about PCI riser card.
    By jssaggie in forum Power Supplies
    Last Post: 08-30-2001, 09:34 AM
  5. Analog or PCI controller card?
    By NuBooJew in forum LCD/Display
    Last Post: 04-04-2001, 12:11 AM
