Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: PCI Sound Card With RCA?
  1. #21
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Also there's a lot to be said for tuning with aftermarket systems (even CarPCs), having EQs set for the amplifiers and speakers you have can sometimes make a big difference.
  2. #22
    Low Bitrate 356Speedster's Avatar
    Aug 2006
    Midlands, UK
    Quote Originally Posted by pantapei View Post
    Fantastic! This could be just what we're after..... I've posted a question on their forum asking if the RCA outputs will work as front, rear & sub.... fingers crossed as at 70 it's not prohibatively expensive.
    2013 Ultima Can Am - Can I fit it with a CarPC?
    MP3Car PC build worklog here
    Facebook full car build here
  3. #23
    Newbie TruCypriot's Avatar
    Feb 2006
    UK, East London
    Just Spoke to the guy at audiotrak, hes saying its very good sound card and its apparently been tested with most of the top hi-if brands in japan considering the card is from japan from what i was told. i'm buy one, £70 price tag isnt so bad too.
    - Forget headunits, its all about CarPCs -
    Progress {|||||||||---}
    Helix 5ch Amp @1850w
    Helix 17cm Component speakers x 2
    Audiobahn 12" Sub @400w RMS
    boot mod
  4. #24
    May 2005
    Conyers, GA
    Quote Originally Posted by 356Speedster View Post
    Fantastic! This could be just what we're after..... I've posted a question on their forum asking if the RCA outputs will work as front, rear & sub.... fingers crossed as at £70 it's not prohibatively expensive.
    You are aware there are only TWO RCA connections on that board right? Plus the two Optical S/PDIFs. The other connector has 3.5" Miniplugs on it. More than likely, Mic-In, Line-In, Front/rear/sub-center/side outputs.
    It does look like it's another pro-based card, but it does state it supports the surround formats.. so maybe it will be good enough!
  5. #25
    Feb 2006
    UK, East London
    Red face
    Quote Originally Posted by Jahntassa View Post
    yep it has, the good thing about this card is its shielded from cpu and hdd background noise, and im hoping it will cut most of the engine and amp noise too.
    we will soon find out, ill post a lil review of the card as soon as i get it.
    boot mod
  6. #26
    Jul 2005
  7. #27
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    have you looked inot the echo gina 3g card? it has balanced outputs but you can easily make a cable to convert that to an unblanced rca. I'm really happy with mine. another option is a usb dac and an external x-over (unless your amps have internal x-overs and passthrough's) I'd also strongly look into the emu line of soundblaster cards...great great cards.
    i also have an m-audio audiophile 192. it has true 24/192 and has balanced i/o (2 chan each so youd need the same equipment requirments as if you were to go with a usb dac) I'll sell it to you if you want :-)
    also... there is always the pxa-h701...
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #28
    May 2009
    could this solve your problem just get a sound card with one rca output as we all know thats a easy find then get a eq such as
    http://www.dbdrive.net/speedamps_speq5.htm
    because that eq only has one input per chan (main / aux) u run the one rca from the sound card to the eq which then splits the chans out to sub front and rear then just set the volume on the computer at like half or wat is best for your application then use the eq to be the main volume control
    it dosent solve the mic issue but it might solve the rca output issue
  9. #29
    May 2009
    Quote Originally Posted by gumbie View Post
    Thread from the dead LOL.
    This is incredibly easy.
    Www.console.jp and any asio card (most pro cards) you can even add allocator for cover. Dozens of choices. You choose which RCA does what including input and draw out the path
  1. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
  2. Sound Card discussion, 4.1, sound quality, need help
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-19-2005, 10:47 AM
  3. Sound Blaster Live 24-bit 7.1 Audigy Sound Card
    By djXternal in forum General Hardware Discussion
    Last Post: 04-25-2005, 04:49 PM
  4. 5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more
    By eatyummypuppies in forum Classified Archive
    Last Post: 06-29-2004, 08:19 PM
  5. Need advice on which sound card to use
    By mtmsol in forum General Hardware Discussion
    Last Post: 06-22-2001, 01:39 PM
