Results 1 to 10 of 19
Thread: usb to ide
    Low Bitrate Iguana2020's Avatar
    Jul 2006
    panama
    Arrow usb to ide
    ok I know it been ask before. but i look at this forum and I can not find and aswer to my little problem
    any way here it is. trying to connect my dvd rom to my pc via usb to ide.
    to start. I have the usb to ide cable plus the power cable.
    when i connect my dvd rom my computer see the drive ok. but every time i insert any kind of disk on the unit. nothing happend.
    no matter what kind of diskI put in the drive, it say please insert disk.
    I try on my dvd rom the jumper to master, slave, the sc. even with out a jumper and nothing happend same problem
    no extention on the usb cable yet since Iam in testing phase.
    having in mine. that I have good power and new dvdrom. can anyone tell me what is the problem here
    Newbie nazerine's Avatar
    Aug 2006
    Quote Originally Posted by Iguana2020 View Post
    when i connect my dvd rom my computer see the drive ok. but every time i insert any kind of disk on the unit. nothing happend. no matter what kind of diskI put in the drive, it say please insert disk.
    Any kind of disk? ie; dvd-rw/r/+r/+rw ? Or discs with data already on them, or pressed real discs ? Ideally if a disc is blank, and you try to access the drive it will say "Please insert disk".
    Have you tried using any burning software, directly selecting the drive and burning some data?
    Jul 2006
    panama
    yes any kind of disk not empty disk. for example dvd movies. software movies foto cd music cd.. also remember this is a dvd rom is not a dvd r. so it will not burn any disk.
    Mar 2006
    Colorado, but Canadian!
    That happened to me too only every disk showed up as an audio disk with 1 track 0bytes big?
    Basically I got a new IDE-USB converter, and all was good.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2006
    panama
    so you are trying to tell me that the one I have is no good????
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    I had this problem with my drive. It does not work if connected to USB HUB. Try to connect directly to the USB port on your computer. If fixed mine problem
    Jul 2006
    panama
    I dont have a hub.
    Feb 2005
    where are you connecting the power cable? USB Ports only can draw 500mA and a USB DVD ROM (CD-ROM, DVD-RAM, etc) need about 1A.
    You need the usb connection (where data flows) with 500mA, and another source of power, BUT, the other USB port (typically USB connectors has two ports) share the 500mA current, so you should connect it to a PS2 (Keyboard) connector.
    Aug 2006
    Quote Originally Posted by yargon View Post
    yargon has a very good point. My two external dvd burners both have external power sources. Perhaps this is the source of your problems...
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Quote Originally Posted by nazerine View Post
    This particular one shows 5V/1.4A
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 08-26-2011, 09:30 PM
  2. IDE to USB
    By UM_Fan in forum General Hardware Discussion
    Last Post: 01-16-2007, 10:29 AM
  3. driver issues with usb to ide adapter
    By jermkesler in forum General Hardware Discussion
    Last Post: 08-31-2006, 10:09 PM
  4. IDE to USB adapter & Hibernation problem
    By nkotch in forum General Hardware Discussion
    Last Post: 03-15-2006, 05:55 PM
  5. Slimline DVD + IDE adapter + IDE -> USB adapter = no drive in Windows?
    By WiCKeD 5.9L in forum General Hardware Discussion
    Last Post: 08-04-2005, 10:49 PM
