Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Hibernation drawing too much power...
    Variable Bitrate Borte's Avatar
    Jan 2006
    Norway
    Hello everybody!
    I'm hoping somebody could help me out with this strange hibernation issue (I have searched but came out with no good answer to this).
    I have a Dell c610 Laptop in my car, which works just fine for everything besides the hibernation issue.
    The computer is wired up so it powers on with the ignition (receives a pulse on the power button), when the usb is activated the power supply to the computer turns on via a relay (it boots from laptop battery power). This works just fine no problems here... Then when I turn of the ignition the relay for the power supply turns off and the computers runs off laptop battery. The software is set to hibernate after 10 minutes on battery power, which it also does.
    The problem is that when I leave the computer in hibernation for more than approx. 12 hours the battery in the laptop is dead, stopping the computer from booting up since it starts off laptop battery.
    This issue started after I changed my hard rive from the original 4200Rpm 10Gb disk to a 60Gb 7200Rpm disk.
    I had to reinstall my operating system (winXP) when swapping the disks and that’s when this started to happen.
    One thing I have noticed is that after I changed the disk, hibernation is way faster. Now it takes about 10 seconds to hibernate. Before it was about 10 minutes...
    I tried reinstalling WinXP but still no luck on this issue.
    I turned the disk caching off too see if that had anything to do with it but it still gave the same result.
    It doesn't sound like changing from a 4200rpm disk to a 7200rpm disk should cause this big difference in time.
    Does anyone have any idea to what causes this difference in hibernation time and what is causing the computer to draw more power when hibernated?
    Btw: Laptop memory is 128Mb so it's not a lot of data to write during hibernation.
    I hope this explanation makes sense to the one reading it...
    Cheers
    Borte
    Failure is not an option...
    _________________________________________
    The open source C# Front End -> OpenMobile
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Hibernation should take no power at all once hibernated, are you sure you are not running standby. Also check that nothing is drawing on 5v standby if you haven't shut that line off after hibernating.
    Edit : ignore 5v standby comment, not necessarily relevant for a laptop.
    Jan 2006
    Norway
    Thanks for the quick reply..!
    Windows says: Hibernating... and the progressbar comes on the screen.
    I've been thinking about if its in standby mode too but can it go into standby even when it says "hibernating... bla bla"?
    I even tried manually activating hibernation from both winXP and RoadRunner but it's always the same result.
    Cheers
    Borte
    Apr 2000
    Bedfordshire, UK
    Any USB devices? Are they still being powered after the laptop powers down?
    Jan 2006
    Norway
    I have the following USB units:
    Onboard USB 1.1:
    - 4 port USB hub (used for powersupply comunication)
    - Touchscreen
    CardBUS USB2.0:
    - 4 Port USB 2.0 Hub
    - GPS Antenna
    - OBDII Interface
    All units are bus powered so I dont think they should stay on when the computer is off.
    Cheers
    Borte
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    um this might seem like a dumb question but.... have you checked the laptop battery? using a laptop while its plugged it kills that battery, same with anything else, for instance a cell phone. i bet if you charge that battery and then shut down the computer instead of hubernate it wont boot up 12 hours later either.
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
    Aug 2006
    That's normal for laptops as far as i know, but i'm not sure about laptops. With my CarPC if i leave it in hibernation without cutting the main power, it sucks my car battery! That is biggggger than a laptop battery.. then i guess 12 hours for you is something fair. For the desktop this is caused by the power drain from the USB ports.. that's why the automotive PSU does have a 12v monitor to cut off completely the power. I usually cut it with a switch when i place my car in the box, just to be 100% safe.
    Jan 2006
    Ft. Bliss, TX
    Quote Originally Posted by ARCTiC View Post
    That's normal for laptops as far as i know, but i'm not sure about laptops. .
    what the what?
    CarPC:
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Are you sure the system is actually turning OFF when it goes to hibernate? Watch the physical laptop and make sure all the lights turn off when windows says it hibernates. If it does, you should be fine. It's possible it's hitting standby instead of hibernate.
    When laptops truely hibernate, they take as much power as 'off'.
    Jan 2006
    Ft. Bliss, TX
    Quote Originally Posted by Jahntassa View Post
    Quote Originally Posted by Borte View Post
    Cheers
    Borte
    well from that post i can guess that its not standby......
    check the battery on the laptop, take it out of the car put it in hibernate and see if it will boot up after 12 hours
    CarPC:
  1. 5.1 Amplifiers with Optical inputs
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 10-21-2011, 04:02 PM
  2. Travla AC/DC power supply cable
    By Change in forum Power Supplies
    Last Post: 07-25-2006, 11:04 PM
  3. Darn ITPS! Need power help!
    By DJ-FrosT in forum Power Supplies
    Last Post: 07-16-2005, 08:40 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
