Results 1 to 10 of 17
Thread: Future Technology - Instant Booting
    Jul 2001
    Richmond, VA USA
    Well maybe not instant but as this article compares... its like turning on a tv instead of booting a computer.
    The benefits of Magnetic RAM, which looks to be very close to becoming a reality:
    http://www.howstuffworks.com/mram.htm
    ( Market ETA 2003-2004. )
    Josh Karger
    By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
    Dec 2001
    Paignton, Devon, UK
    With suspend to ram, I get boot times in the region of 2 seconds. If They could produce a non volatile version of this then I would be pretty pleased - saving electricity as well!
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
    Mar 2002
    Magnetic RAM?
    Oh Lord, no...
    I thought technology was moving away from magnetic storage because of how unstable it is. Can you imagine if you had to throw out these RAM chips as quickly as you have to throw out floppy disks???
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Is it just me, or does magnetic RAM simply = hard drive.
    Perhaps these IBM engineers should work on suspend to disk instead. Each machine should come with a small partition (based on the RAM size) that the BIOS writes the contents of RAM to on shutdown. This partition would be a proprietary filesystem, and would be automatically resized in the event you changed the amount of RAM....Wait a sec, hasen't this been done before?
    May 2002
    Sef'Kylar
    what about solid state memory (i think this is what the call it?) like smart media cards? It's a bit more expensive but the data lasts a long time and it can be really fast.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Jul 2001
    Richmond, VA USA
    Well what about this... it's mentioned at the end of the MRAM article... sounds interesting as well, what are some problems/benefits?
    http://www.howstuffworks.com/holographic-memory.htm
    Josh Karger
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    A harddrive is magnetic storage, but slow, and dram is fast, but unstable. combine them into a nonvolitile fast solution, and that certainly is something. and this is certianly more relatable to a hard drive and not a floppy drive. and flash memory is quite fast, as well as nonvolitile, but it has a limited life span of write/erase cycles.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Apr 2002
    South Coast, UK
    They`ve got to be kidding? Using magnetic ram was dropped decades ago (then call magnetic core memory, using ferrite cores to create the magnetic field), because solid-state memory is far more reliable. Who the hell wants to take a step back?
    IBM are clutching at straws with this, just cause they aint that big anymore and they want to be on top again.
    Jun 2001
    Boise, ID (USA)
    I get 4-6 second cold boot times right now, I think its only a matter of time until computer speeds approach instant on...
    Windows XP
    Athlon 1600+
    512 Megs PC2700 DDR CAS2
    7200 RPM WD Hdd
    May 2002
    Roseau, MN
    Don't worry guys, everything's going optical in a few years anyway.
    HU: Clarion 9575RZ
    EQ: Clarion 90EQ
    Amps: Dei 1100d and DEI 400
    Front Stage: Morel 6.2 Comp Set
    Subs: 2 IDMAX 12 D4s
    ...and a hell of a lot of MDF, Fiberglass, RAAMAT, and Expanding Foam
    To come: 200 MHz Mobo, 30 Gig HDD, Sproggy MK 2.6, LCD?
