Results 1 to 5 of 5
Thread: smart fan controller
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    hey guys,
    just purchased this handy fan controller:
    http://www.coolerguys.com/840556051558.html
    it adjusts the fans' speed based on internal case temp. My new install has the computer practically hidden. my sub amp and the pc will be sharing the same space so i'm hoping that this and four 3" fans (two intake, two exhuast) will keep everything in check and minimize noise.
    anyways...seems like a handy device that would be ideal for our applications
    here is the writeup from that site:
    Tired of that every present loud fan noise? Here is a great simple solution. The Sunbeam Pyramid Controller. Since your computer typically only runs at a fraction of the capable speed, there is no need to run your fans continuously at full speed. While other products ask you to dig into your case to make an adjustment, the Pyramid is a smart device that changes the speed of your fans automatically
    * This latest 'high power' design is capable of controlling 3 to 6 fans
    * Power consumption of 2.0 Amps. (24 watts total fan power)
    * The fan levels will adjust automatically to the system needs.
    * Several fail safe features.
    * 5(five) super bright LED
    * Automatic warning alarm buzzer and LED flash) on high temperature.
    * Lighted enclosure in a clear case
    * 4 Pin Molex connector / pass-through
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    i wondered about using these
    how does it detect the temperature? is it just a sensor in the box, or does it have temp leads that you can mount different places?
    Dec 2004
    Los Angeles Ca
    i guess it's a temp sensor at the tip of the pyrimid. I wonder if it can be hacked or if it's just really small and can fit anywhere.I guess i'll find out soon enough
    M10k
    My Car Pc Install
    My Boat Pc worklog
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    rofl, someone should hack an ir temp gauge
    point it at the cpu, and adjust fans accordingly
    lol
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok let me explain.. old fans had 2 wires..just voltage.
    then came the 3 wire fans.. voltage + RPM sensing..
    however you can find fans with 4 wires..voltage+RPM+temp sensor.
    they are used mostly in industrial situations. the fan is internal i think
  1. Aerogate3 Cooling Fan Controller
    By sirlemman in forum Newbie
    Last Post: 02-20-2005, 01:41 AM
  2. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 09:30 AM
  3. Xbox controller...
    By thekage in forum Input Devices
    Last Post: 12-02-2004, 12:02 AM
  4. WTB: 10.4" touch screen overlay & controller
    By Cordell in forum Classified Archive
    Last Post: 08-06-2003, 07:15 PM
  5. allens controller and 10.4 lcd
    By forgoten in forum LCD/Display
    Last Post: 02-04-2002, 12:28 AM
