yes
Okay, here's the deal. Using a laptop as the computer. Took it apart, found the button, used a multimeter and determined the following. THe button has 4 leads. When the button is up, each pair goes straight across while when it is pressed down, they switch. Please see the attached diagram. It is horrible, but it gets the job done.
Now, I want to relocate the button so it's in my dash, so I can boot the computer when I want and turn it off when I want. I have this button from Radio Shack:
http://www.radioshack.com/product.as...5Fid=275%2D618
Can I use this button to replace the one in the "schematic"? If so, how? If not, what kind of button do I need? THanks!
yes
abcd-1
Nevermind. I tried something and now it works perfectly.![]()
I am looking to move the power button for my computer to my dash, I do not use the auto startup feature or shutdown feature becuse I don't use the computer all the time so I am just using an old switch from a computer to the MoBo for now but it won't mount in the dash correctly. I am wondering what type of switch I would use. I see many at radio shack. Anyone know what p/n would be a good one for me to use. Any help would be greatly appreciated.
Harry
any switch with "normally open" and "momentary" listed in their description will be fine.
this link shows some, but make sure they are not the normally closed (like the fourth one down) as they will not work properly. I cant filter it out.
2005 Ford Focus ST
i already now what kind of switch it has to be, however. how long do you think the wires to the switch can be and have enough current to still correctly function? i ask cause about 15-20 feet from front dash of my car to the trunk were carputer is.
thanks
that should be just fine. Its a low power circuit, so no big deal.
2005 Ford Focus ST
