Results 1 to 9 of 9
Thread: What is this type of cable called?
    Nov 2005
    Just as the title says, what is this type of cable actually called? I need to extend the control buttons on my touch screen about an extra foot or so since where I have the screen now isnt large enough to have the buttons where they were made to be. I would just solder, but its so small I dont think I could do it without accidently bridging some of the pins. BTW, there are 13 "wires" in the cable
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    it lookts like ribbon cable to me... are you trying to find the exact name? like "usb" cable or "ide" cable? its probably manufacturer specific if its internal from the buttons to the board.. hopefully some hotshot will show up and save the day.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    easiest thing to do when soldering ribbon cables, is to use a utility knife, and seperate all the wires, its kinda tedious, but just cut about an inch or so, so you have one wire off to the side, solder that one, then do the next.. so on..
    might be the only way, trying to find ribbon cables sometimes is a PIA
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Try digitalww.com, armen may have some longer cables for that. Send him an email, his website doesn't show all of what he's got. What kind of a screen is it from?
    Tidder
    Try RevFE
    Nov 2005
    Thanks for the replies. Ive tried searches for ribbon cables, but all that I come up with are actual individual wires. Heres another pic to further show exactually what cable it is. It is not individual wires, more like printed metal only plastic. Its from a 7" touchscreen monitor. cant remember what brand now and the part that says it under a bunch of bondo, so im not gonna look it up. Ive tried googling every set of numbers/letters printed on thecables, but got nothing. I might give a shot at seperating the cables with a knife, because i think that should work for what i need. Only problem is, I need both ends to have the flat connection, so im going to have to cut in in the middle, stip off the covering, and then seperate it.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    FFC - flat flexible cable
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by psyrex View Post
    I've wondered about that for a long time as well. Now I know.
    Psyrex, do you know where I could buy FFC individually? Everything that turns up on google seems to be OEM/custom order stuff.
    Nov 2005
    Alright, one more question then. What is the pitch referring too? i know the number of wires (13) but what is the pitch? Im guessing something like the space between wires, but I see standards of .5, .7 or 1.0 on websites. Whats that in? mm? Also, is it the space between wires, or the distance from the center of one wire to the center of the next?
    Thanks for all the help.
    Constant Bitrate KaBoOoM's Avatar
    Oct 2005
    Portland, Oregon
    On ebay there is usually rolls of this stuff. You don't need a 13 wire one either, so if all you can find is a 20 wire than only solder 13. If you are soldering only the gauge and needed length should matter.
    *edit* And here is a site with rolls http://www.action-electronics.com/ribbon.htm, just found it
    I'm hungry
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
  3. Lilliput Cable Extension
    By djXternal in forum LCD/Display
    Last Post: 10-12-2004, 08:14 AM
  4. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 09:29 AM
