Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Oh where have all the Shutdown Controllers gone (and boot time)?
  1. #11
    Feb 2005
    number of fonts shouldn't matter since windows 3.1.
    Windows 3.1 used to load in a list of all the installed fonts when it started up. Windows 98 and later removed that. Number of fonts mainly effects disk space.
  2. #12
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Quote Originally Posted by SuperAJ
    Hey guys,
    ... I have also been told by an mechanic (very experienced with car wiring and electrical setups) that in order to keep one of my wires from frying out, I need to run a direct wire from the battery to the DC-DC converter and use it only for the power supply, which has been done bypassing the ignition +12 wire...
    Thanks in advance!
    SuperAJ
    That's a very good advice. Did he also tell you to put a fuse very close to the battery?
  3. #13
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    ive actually timed my system to about a 20 second reload from hibernate boot time. and this is with 512MB RAM. of course it also helps to have a nice bios which can be set for super short post times (just short of a second on a soft restart or about 5 seconds or less on a cold start due to HD spin up)
    Your everyday carpc geek and tech guru at your service. *bow*
  4. #14
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Just get a CarPC EZ to solve your SDC problems. It is the solution to all your issues and even includes inverter control (if you were to ever use one). MP3Car sells it here in the store.
    -HD
  5. #15
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    holy old thread batman.
    肚子笑痛了
    S60 Install
  6. #16
    Jan 2005
    Warren, Ohio, USA
    Quote Originally Posted by jcdillin
    DAMN IT!
  7. #17
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    Shutdown controller
    Try www.mini-box.com they have an ITPS with shutdown controller for under $40. If you already have a power supply remove the voltage regulator and use it just as a shutdown controller. Sorta expensive but it will work and it's easy.
    Booting into the OS takes us 30 seconds with Windows XP. Our bios with everything tweaked takes 8 seconds and then it takes about 22 seconds for the OS to boot from hibernation.
    We wrote a tutorial on it. It only helps users running XP.
    http://www.12vsystems.com/Tutorials/...oot-times.html
    I have never heard that using hibernation can damage LCD's. Do you have any proof or docs I could look at. I would be very interested.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
  8. #18
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    for that shutdown controller you asked about i got mine from mastero. was about $25 shipped from india. works perfect!
