Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: CARPC and HDD life in a drag car????
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by SFiorito View Post
    yeah, that'd be cool like a hobbiest version of a pit team.
    that'd be a good solution as long as he's got someone in the stands, but if he's alone then he'll need something else of course.
    True, but with a 9 sec car, I could almost guarantee he has someone else with him. And, even if not, I doubt he drives the car to the track. He can set up a computer/carputer/laptop in his tow vehicle, and just have it record the entire time he is there. Wouldn't be too bad.
    I have done this when I went to the track (not the drag, the one with turns ,in both directions) I VNC'd to the car while a friend was driving, and monitored boost, fuel, and spark, from pit lane. It was pretty cool.
    Michael
  2. #12
    Oct 2004
    NY
    dude, how bad can the vibration's be with a 9 second car... vibrations are easy to isolate, mounted in a box on fluid mounts the vibrations shouldn't be so much of an issue, I think I'd worry more about the g forces of the launch, but even so, I ran a national in the 9's with 1.29 short times with the laptop for the dfi on the passengers floor,car launched like it was rearended by a semi... no issues or glitches in datalogging at all....
    I think your making this more of an issue than it needs to be, you shouldn't have any problems unless you directly bolt it to the floor directly over the header exit..., isolate it even a little & you'll be fine, & use a laptop drive rather than a 3.5".. now if you told me your running a top fuel car or something, then maybe theres more concern, but you should be fine...
  3. #13
    Newbie guillemasco's Avatar
    Nov 2004
    Cordoba, ARGENTINA
    more car pics
    Carpc: 90%
    CarAudio: 122.8Db
    PC: 50%
    First CarPc in Argentina!!
  4. #14
    Sep 2006
    Thanks all for your advice, got some info on logging size and it isnt too big, think i will go solid state root, XPe on CF and 2gb or similar thumbstick for the logs. If he really gets bored then he can take the thumbstick home and weigh up the logs.
    Ok a lapotop drive will be far more robust than standard, i agree though i live many miles away and dont fancy travelling to fix his hdd IF it fails. Wouldn't be very good if he's on the final and the damn thing wont boot. Ok we have all had scenarios: "mine survived three crashes and two rolls, one of which off a bridge" then we get "CARPC= dead, after hitting a curb my HDD failed!" making it more of and issue than it needs to be?! i dont think so, i want something that will last.
    How did you VNC the car? wifi reception is restrictive.
  5. #15
    Apr 2005
    Quote Originally Posted by turbocad6 View Post
    My drag car bounces quarters out of the cup holders and it only runs low 10s. It just depends on the cam lope. a Tubo car obviously will run a lot smoother, but most fast RX7s have a V8 conversion.
    What are the 60 foots? If it is a turbo car then the shock will be much less and a normal HDD will probably hold up fine. If it is a LS1 conversion or something with a 1.4-1.5 60 foot...then I really don't know. Next time use a G force measurement tool and compare the Gs with what the drive is rated for. Also, have him make a pass with a running laptop in the car, if that works with out hainging then so should the CarPC.
    The reason you hear about drives surviving crashes is newer drives have a new technology that locks the head in place when G forces are suddenly increased (i.e. being dropped, or hitting a bridge at 150)
    it sounds to me like he has been using a laptop in his car for sometime now, how is a CarPC laptop drive going to be any different?
  6. #16
    Sep 2006
    No he has never used a laptop on this car on actuall drag runs, he remaps on the road under hard 5th, 6th gear accelerations. i mentioned earlier about him using a power FC controller to MAP, he uses this for the actuall drag runs. Still runs the rotary engine, see pic.
    Think i will stick to the CF drive idea. though will run a HDD with it as a slave for storage, can see how it stands up to the punishment, it probs will be ok but like i said, i want to be sure...
    ...guess the only way is to test
  7. #17
    Apr 2005
    You know they make special equipment just for this, I would look into that. CarPCs jsut have to many bugs, and when you are at the staging lights you have no time to mess with them.
    BTW, tell him I'm really impressed with his setup...if he is in the Texas area I would love to run him sometime.
  8. #18
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by DaVa View Post
    External antennas on both cards. Certainly it will go the 1/4 mile of a drag strip, no problem.
    Michael
  9. #19
    Apr 2005
    Quote Originally Posted by Wiredwrx View Post
    Michael
    I think using a wireless KVM terminal would be the best bet...that way you would have no software, and no harddrive of any kind in the car.
  1. 2002 Skoda Octavia RS carpc in progress
    By Ackeman in forum Worklogs
    Last Post: 11-22-2006, 01:49 PM
  2. Testing out a carpc without a car!
    By mike6789 in forum General Hardware Discussion
    Last Post: 08-14-2006, 05:04 AM
  3. FS Full CarPC system In the U.K.
    By hotponyshoes in forum Classified Archive
    Last Post: 06-24-2006, 01:41 PM
  4. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  5. FS: Toshiba 2.5" 40GB HDD, CarpC Ez 2.2 Inverter Shutdown Controller
    By blackaccrd00 in forum Classified Archive
    Last Post: 04-13-2005, 05:04 PM
