i was thinking that there might be some sort of 50 pin ide cable that you can yank out of a laptop and use that to connect the drive to the adapter...Originally posted by inline4
you cant hack an old notebook because it will stick out just the same.
do laptops have the drive and mobo mounted in a "card-to-card" arrangement without a cable... ive never disected a laptop so im unsure...
ive been told that the easiest way to make a double sided board is to....these instructions are written as if you are using a "press n' peel" type image transfer paper or similar product...Originally posted by JamesDoubbler
Not really sure though since I really need a double-sided board and only know how to etch single-sided.
layout the first side as normal, but add a couple locator marks in the unused corners of the board... something that looks like a target with an X through it is the usual symbol... then etch the board (i assume you are using a copper-clad board, not photoresist), make sure you cover the other side with tape so that it doesnt get etched.... then using the same spacing for the locator targets... layout the reverse side of the board (remember to revese your locators) and when you transfer the image to the board, make sure the locators are lined up perfectly... when you etch the second side... cover the first side with a layer or two of masking tape and make sure it is very secure against the copper... after etching... drill out the holes and you should have the double sided board all set...if you want to drill holes for the locators before you transfer the reverse side, you can do that too, it will make loacting easier.
if you are going to do a "dry-transfer" layout of the board... follow the same procedure.... but you really dont need the laocator holes/targets...
just make sure to cover the side that you ARENT etching with some tape so that it doesnt get eaten away when you are etching the other side.
alternately.... you could make 2 seperate one sided boards with a set of jumper wires that connect the 2 boards..
or better yet... just make a single sided board, with loose jumer wires soldered onto it, and then connect those loose wires to an ide header that you can just plug the main ide cable into...
~mike
LinkBack URL
About LinkBacks
