my plans.. thoughts?
here are the plans i have...
i plan on putting the wafer board in a DIN slot. The PSU behind the dash.. the LCD above the glove compartment on the passenger side, on the left most side of it (i will try to mount it so i can angle it to face me).. the VFD in front the PC, the Extigy and the 3.5" HDD in the glove compartment, and the dvd drive in the PC, behind the VFD (I might switch the VFD location and the HDD.. hopefully one way or the other it would work)
I might change the Garmin GPS to be the GPS 16, and cut and rewire the ethernet cable that it comes with..
anyone have any comments or suggestions? I want to order the screen and the gps first, and then test them out with my laptop. if all goes okay, ill order and build the wafer. what do you all think?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
