Results 1 to 9 of 9
Thread: HELP!!! carputer reboots with ignition restart!
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    hi can anybody please help me my carputer is using jeffs shutdown controller, i turn on ignition the system boots all is fine i turn off igntion say to go get some fuel come back to the car within 5 mins and the system is still online but when i restart the ignition the massive drain on the battery from the starter motor tunrin causes my system to reboot, can anybody think of a solution?
    Sep 2001
    Australia
    try making a tank curcuit for it
    http://austmp3car.tk
    May 2002
    Essex, UK'er
    yes this tank cct sounds like ti could do the trick how do i build it though ? anybody got a diagram?
    Feb 2002
    Ontario, Canada
    i have no probs with my system and i don't use any circuits. I run an inverter to provide power to my PC and i'm assuming you do too. My inverter is hooked up to a switch on the dash so when i turn it on it comes on, turn it off and it's off. No hook up's to ACCESSORY line off the ignition. Is your computer set up to Boot as soon as you turn the key? if yes then try disconnecting the ACC line and hook your inverter up to a 12v line directly to the battery. Then test your system again, if it still reboots while cranking the engine maybe your alternator or battery is dying.
    Got nothing to lose but 15 minutes so give it a try.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
    May 2002
    Essex, UK'er
    no i use a sproggys mk2.5 dc - dc donverter , the system reboot cos the starter motor causes the battrey voltage to ddrop below 8v which is where the feed back regualtor in sporggys psu doesnt provide 12v = from!
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    ^ yep, thats right! ^
    Tank circuits???
    ^how it works
    Advice on tank circuit !
    ^how to build
    do search do search do search
    May 2002
    Essex, UK'er
    thansk but that link still doest show how to construct a tank cct? only masteros suggestion
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    um i believe a tank circuit is just a capacitor in series with a diode....
    pretty simple stuff, just make sure u get large enough components to handle the loads..
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    construct? you know howto solder?
    pc-------| <- cap legs -> |-----------cable--------diode-----------plus
