Results 1 to 10 of 13
Thread: DVD and CD burner dont work above win 98
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    Post DVD and CD burner dont work above win 98
    I have a dvd drive (sony ddu100e) and a cd burner (teac cd-r55s). Neither of these drives will work in any os above win 98. They will both work as normal drives, but the dvd drive dosent play dvd's and the cd burner dosent burn cd's. When i put a dvd in the dvd drive it just tries to read it but cant, its like i put in a bad or scratched cd. Easy cd pro wont detect the Cd burner. I did not try nero. Both of these drives work fine with windows 98. If anyone can help me or point me in the direction of a more approiate forum "this is not in my car computer" i would appreciate it. I know i posted this before but all posts relating to this subject seem to be disapering. I tried searching for my last post using my member nubmer and it didnt come up. Did somebody delete my post?
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Mar 2001
    Cincinnati, OH USA
    Post
    Are you sure you have the most recent driver for each? What OS are you using? You also might wat to try running Windows Update and look at the bottom and see if there is anything listed in the drivers section.
    [ 02-07-2002: Message edited by: Maveric ]
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    May 2001
    Toronto, Canada
    Post
    Not sure about the DVD, but for the burner you need to download the upgrade patch for EasyCD Creator to work in WinXP. By default, WinXP has CD-burning software built in, so try burning a disc using this method.
    Jan 2002
    Post
    for XP you need to install the aspi drivers to get the burner to work.
    Apr 2001
    Here, There, Everywhere
    Post
    the ASPI layer is needed for some burning softwares. I use CDRWIN which needs the ASPI drivers for my SCSI burner under win2K, but Nero will work happly with my burner on a fresh copy of win2K OS out of the box.....
    maybe try Nero as your burning software?
    Project - GAME OVER :(
    Apr 2001
    Post
    Apr 2001
    Post
    Thanks for all your help on the burner. I will try nero tonight. If that dosent work I will try to find the aspi drivers. Now, does anybody have any ideas on the dvd drive? It is a sony ddu100e. It works perfectly with win98, It works fine as a normal drive under winXP. But if I try to play a dvd under winXP it cant read the dvd at all. It does the same thing it does when it reads a scratched or bad cd.
    mike
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Post
    Are you sure that your copy of the dvd software functions properly under win2k? if your hardware is that old, is your software that old too?
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Apr 2001
    Post
    The dvd drive cant even read the cd. Even with no DVD software i should still be able to see the contents of the dvd from my computer.
    Originally posted by MP3DUB:
    <STRONG>Are you sure that your copy of the dvd software functions properly under win2k? if your hardware is that old, is your software that old too?</STRONG>
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Tried applying any firmware updates?
