Results 1 to 4 of 4
Thread: Info on installing hardware...
    Newbie NebulousOsiris's Avatar
    Oct 2006
    Ballarat
    Hi,
    I'm pretty new to the whole carputer thing. I was wondering whether anyone can help me with some answers to my questions...( I apologise if this is the wrong area for this type of query, couldn't find any relevant areas...)
    I have a M1-ATX powering my computer a touch screen and 4ch Amp. They all need 12V direct source to the battery (assumption).
    My question is, how do I power all these from the battery? Do I need to supply separate in-line fuses for all three components? Also how do I fix the wires to the + battery terminal?
    Your help is GREATLY appreciated!!!
    True Refinement Seeks Simplicity
    Elsewhere
    One way is with a distribution block.
    Run one thicker gage wire (4AWG or thicker, typically) from the battery to the distro block, which then splits the power up to thinner wires (8 or 10AWG, typically) that run to each of your components. My suggestion is to get a distro block with fuses for each of the components.
    For ease of wiring, StreetWires makes a combination distro block for both power and ground and all the power connections are fused, although the fuses are sold seperately.
    It's a nice little package, IMHO.
    How about the Wiki?
    Oct 2006
    Ballarat
    WOW, that's was a damn quick response, thanks heaps for that!!! I'm guessing i should have this as close to the battery as possible?
    Thanks again for your help!!
    James
    Elsewhere
    Actually, no.
    You want a fuse on the thicker wire close to the battery, definitely. You want the fuse within 18" of the battery.
    The whole idea behind a distro block is to only run one long cable run (albeit a thicker wire) and multiple shorter ones, as opposed to many longer runs.
    How about the Wiki?
  1. Registration and hardware codes
    By segerdahl in forum StreetDeck
    Last Post: 06-02-2007, 07:51 AM
  2. Replies: 43
    Last Post: 10-31-2006, 11:00 AM
  3. Hardware Compatibility List - 800x480 Video Cards
    By alfabob in forum LCD/Display
    Last Post: 10-10-2006, 08:54 PM
  4. Weird Registration Code and Hardware Code problem
    By lookinco in forum StreetDeck
    Last Post: 09-30-2006, 02:25 AM
  5. File Info / Movie Info
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:42 PM
