Results 1 to 4 of 4
Thread: Commell LV-677 and Mini-PCI
    Sep 2006
    Anyone ever use mini-PCI to PCI? I have a PCI board and want to use it with the Commell LV-677, while still being able to use the PCIex16 slot for video. I can not seem to find any adapters though.
    Elsewhere
    Something like this: http://www.interfacemasters.com/prod...380/index.html
    They are awkward placement, from what I can see and probably wouldn't work in an unmodified case.
    [EDIT]
    My original link wouldn't fit in the configuration of the Commell board you specified. This one above looks to be more flexible, although the statement about unmodified cases still holds true.
    How about the Wiki?
    Sep 2006
    Thank you for the link. It seems that the cable would be long enought to go around a PCIeX16 card. Should work out.
    I plan on using a Commell LV-677 and a Core 2 Duo (merom) 2.0ghz. This should all work out well.
    Any case recommendations for mini-ITX's?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by boypdp View Post
    Get a stronger power supply the m2atx is not working right. I am not getting a good jump start. The system is fast but I am having a power problem right now.
    I am currently running
    CoreDuo T2400
    LV-677
    80 gig sata hard drive
    slimload dvd/cd room
    2gig ddr2 533 dual channel
    256mb pci-express ati graphic card
    not enough power any recommended power supply for this unit. The m2-atx is not working. I have tested 3 of those power supply
