Results 1 to 7 of 7
Thread: Power External USB via Firewire?
    Sep 2005
    Pomona, CA
    I remember seeing something long ago about powering a USB/Firewire external drive (I have a Seagate 300GB external) via the Firewire port and sending data via the USB port. Does anyone know about this? I've searched far and wide and come up with nothing except an overpriced enclosure that does it...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Mar 2006
    Unless you already have a firewire port on your mobo, which I don't, you will need this first.
    http://www.logicsupply.com/product_i...roducts_id/185
    Then once you have that you need to get an external enclosure, something similar to this.
    http://www.meritline.com/ultra-slim-...cessories.html
    And then obviously a firewire cable to connect the two..
    EDIT: That first link is for EPIA mobos only.. so if you don't have an EPIA mobo I doubt it'll work.
    Sep 2005
    Pomona, CA
    Yeah, I have an EPIA M10000...
    I have a Seagate 300GB USB/Firewire external drive (as stated above), but I can't figure out how to make it power from the firewire. Will it just do it automatically? Maybe I don't have enough power so it didn't work - will have to test it on my home computer I guess.
    Carputer Progress:
    Teardown PC [100%]
    Mar 2006
    From my understanding and reading (which I hope I am correct) if you have the external drive it should just power from the firewire. I am assuming it is the same concept as my ipod. I hook it up to my computer through firewire and it powers the ipod and such.
    Sep 2005
    Pomona, CA
    Well, supposedly there is enough power for the HD via firewire, but not enough for both data and power, so it is necessary to have both USB and firewire work, but the computer would try to transfer data via firewire instead/also, which is not good. There must be some app out there that can tell the computer which interface to use. I bet the iPod uses half the power (probably less than that) than my HD (~36 watts/3 amps over 12 volts). I dunno though - I gotta do some more searching, it has to be out there on the net somewhere.
    Carputer Progress:
    Teardown PC [100%]
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    A 3.5" Desktop drive will not be able to power off firewire. I'm pretty sure no way, no how. There isn't 12v in a firewire cable.
    2.5" Laptop enclosures and small CD-ROM enclosures (like for the slim drives) shouldn't have any problem, however.
    Sep 2005
    Pomona, CA
    Yeah, I've come to the same conclusion - thanks. I will be powering it with a hacked molex from my carputer just like I did with my touch screen. I think I'll have to upgrade to the M2 though - kinda sucks that it wasn't around when I originally bought my 90W M1
    Carputer Progress:
    Teardown PC [100%]
  1. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 01:05 PM
  2. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  3. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
  5. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:50 AM
