Results 1 to 10 of 14
Thread: High qualtiy USB sound card?
    Newbie Dichotomous's Avatar
    Oct 2006
    gotta be External cause its a laptop without sound, and yes I did search, that out of the way, whats got a good strong signal, hopefully with RCA outputs, or at least just really good output. looking for a strong s/n ratio and lots of output voltage. going to be connecting to a fully infinity referance amp/speakers setup, so I want it to sound really nice
    now if I could just figure out how to put a computer on the SV.....
    Nov 2005
    ESI - Gigaport
    USB, 8Channel, RCA outputs.
    expensive.
    peace
    Oct 2006
    well, while that seems to meet and exceed my needs, it seems to do so by quite a lot. not that that is a very big problem of course, just, you know, well if they had that in the 2.1 or 4.1 formats for cheeper I would be say yay, and yes I know it could do that itself. anyways. I found this http://www.creative.com/products/pro...&product=10769 and was wondering if anyone had tried it or if it looked decent.
    most of the creative products say they are rated at 2Vrms on the outputs, I am wondering if that is 2 volts per output, or per channel, because that would obviously make a big difference, since 2 channels are gonna run off each out put. well, 2 channels will run off one output, only one channel will run off the rear output on my setup. also, if I had, say, that 8channel sound card, could I "bridge" any of them together? say, I set up two or three of the channels putting out the same signal and then use a Ysplitter to combine them together for a more powerfull signal? and would this work for a typical 5-6 channel card as well?
    I'd really like to get 4Vrms signal to my amplifier from the sound card. 2Vrms would be ok, but I would prefer higher. I have a rockford HU that puts out 2V and that sounds ok, but I had at one point put an alpine with 4v pre-outs and it sounded so much better. then again, since I intend to keep the rockford as an auxiarly and for colder weather and untill the computer boots up (again using Ysplitter to combine signals) then maybe I should try to match the voltage so the amp gain is the same for either input. if the card really puts out 2Vrms to each channel, then it would be all set up straight as it is, otherwise I would like to combine the channels together if possible.
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    I like the Audigy 2 NX (external USB 2.0 7.1 Surround). It's got some quirks in a home theater setup, but with my infinity speakers, and clarion amps, it's great. ESPECIALLY at 96khz and DVD's. Night and day difference from 48khz.
    It supplants a CMSS fake surround mixing when playing non surround media (MP3's etc), which actually seems to work ok.
    That gigaport looks an awful lot like this awful product that I tried once
    http://img.clubic.com/photo/00035090.jpg
    Maya EX USB
    http://www.mpc.ru/base/86/4359_4.jpg
    ESI Gigaport
    I heard some funny issues with the pcmcia version of the Audigy 2, can't remember what exactly they were, maybe bus noise? I can't seem to find ANY good USB 2.0 5.1 or higher sound card still available Avoid the turtle beach roadie and the maudio sonica theater (though the sonica is pretty good, still usb 1.1 only, which means no 96khz for more than 2 channel audio). I setup 6 maudio sonica theaters/laptops to run DJ mixing for dew tour events (extreme bmx, freestyle, motocross on espn). I think we used AISO drivers, which helped with almost every problem, I just don't think usb 1.0 is something to keep though.
    It's 2v peak to peak per channel, not per output on the audigy 2nx, not sure on the ZS laptop version. I guess you could try to combine the outputs, but not really sure if the unit would like that, since you are changing more than just impedance, you are adding a voltage source! Since the ouput ports are all shared on these devices (except maybe the gigaport), you have unbalanced audio, meaning 2 channels share a ground at least. Could cause some noise issues, but none bad enough for me so far (2 years).
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Oct 2006
    how much does teh audigy nr2 run?
    Jul 2003
    Naperville IL
    $45 to 95 on eBay. I think they were 129.99 new. I have two, one as a spare. I don't think anyone sells them as new now, but they were sold until recently through circuit city and compusa.
    91 Stealth RT/TT
    Jul 2003
    Naperville IL
    I never thought about firewire, because most of that stuff is MAC only (I have a mac, not in the car though).
    This looks REALLY good for car use,
    http://www.audiomidi.com/FireWire-Au...PID=392&AFID=3
    EDIT: Maybe not for 5.1 surround/dvd, but for normal car class audio, 4 channel. I think it can put up to 6dBV per RCA output.
    91 Stealth RT/TT
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    usb dac and an external x-over? (unless your amp(s) have internal x-overs and the passthrough feature so you can daisy chain amps from a stereo set of inputs)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    did you look at the Turtle Beach Roadie in the store by our sponsors at MP3Car.com?
    http://store.mp3car.com/SearchResults.asp?Cat=42
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Oct 2006
    yeah external xover I gess, if thats the right terminology, Ijust want to boost the voltage signal so the sound comes out better
  1. USB Sound Card muted upon resume from hibernate
    By ZR5 in forum General Hardware Discussion
    Last Post: 09-19-2008, 11:34 AM
  2. Audigy 2 NX Sound Card USB Problem
    By bl3nd3r in forum General Hardware Discussion
    Last Post: 06-22-2006, 05:01 AM
  3. Want to buy: USB Sound Card 5.1 SB
    By vinzer in forum Classified Archive
    Last Post: 01-08-2006, 10:22 PM
  4. USB bus bandwidth and USB sound cards
    By Merzbow in forum Car Audio
    Last Post: 10-18-2005, 01:13 PM
  5. Sound card vs USB card
    By Splinter in forum General Hardware Discussion
    Last Post: 09-06-2005, 10:49 AM
