Alpine AiNet aux input adapter SOLUTION!!!
After talking with Alpine tech support, it seems that Alpine HU's that have a setting on the menu to turn the MUTE funtion off, should be able to use the KCA-121B AiNet-RCA adapter to get an AUX input without a CD Changer. The guy on the phone told me that it depends on the model of head unit. If you have the AUDIO MUTE function on your unit and you can turn it off in the menu, you CAN use the adapter. Thank GOD! I was cringing at the thought of using an RF modulator, or having to shell out some $$ for a crossover. Basically, all you have to do is this:
1) connect the external source to the adapter
2) connect the adapter to the AiNet port on the HU
3) turn OFF the MUTE function on the unit
4) find the pink/black audio mute lead (or whatever color yours is)
5) install a switch that switches a ground to the mute lead.
Here's the doc online straight from Alpine:
http://www.alpine1.com/html/D2_n_70_35_n.html
Hope that helps all you Alpine users!!! (or anyone else with an AiNet port and no aux jack/hack).
- Aaron
unfortunately my unit seems so old that it wont work, it has no MUTE or AUX feature, no setup or menu.. TDA7563
thinking about emulating CDchanger with arduino or buying and splicing cdchanger, or just opening up the unit and find were to solder rca input from tape deck..
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
