Results 1 to 10 of 20
Thread: aopen i945gtt-vfa users: usb powered during standby?
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    hi all, i'm building v2 carputer with this mobo and am getting close to putting it in the car. testing right now with the standard power brick that came with it i see my 3g usb modem powered while in standby: is this true for others? i'm afraid that all of my usb devices will drain the battery if i can't alter this behavior.
    thoughts / experiences?
    TIA,
    Per
    Jan 2004
    Seattle, WA
    i suppose this is no different than on any other mobo and it brings me back about 3 years when i brought this up and it grew into the 'mother of usb power threads' as per someone else on here....so - - feel free to disregard ;-)
    Registered User
    I noticed this once i upgraded to the latest bios so i went back to the original bios.
    Jan 2004
    Seattle, WA
    and that fixed it? i.e. with the original version BIOS the usb bus is not powered during standby?
    Registered User
    Yep
    Jan 2004
    Seattle, WA
    any chance you still have the original BIOS handy? i didn't save mine before upgrading. send to per at thefarnys.com if possible...it'd be greatly appreciated.
    Registered User
    My board is currently with Aopen but once i get it back i will extract the bios
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    This post might help, so you can tell windows to shut off USB when in standby (not usually a default option under windows power management)
    http://www.mp3car.com/vbulletin/show...860#post942860
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Jan 2004
    Seattle, WA
    kalt - any update? get the board back yet?
    thanks,
    per
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Not sure what power supply you are using but I have an Opus 150 and I took care of this by having the Opus engineers modify it for me so USB is not active and it works perfectly.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 02:34 PM
  2. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-14-2006, 11:00 PM
  3. FS: 4-port powered USB 2.0 Hub $10 Shipped
    By Altimat in forum Classified Archive
    Last Post: 02-14-2004, 03:30 PM
  4. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 02:44 PM
  5. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 03:21 PM
