Results 1 to 6 of 6
Thread: boot from CF?
    May 2000
    Ft Gordon, GA
    Question boot from CF?
    ok. i have heard several people mention booting from a compact flash card to greatly improve boot time. How is this done? what are the boot times (preferably divided into post and boot) you get from this setup? also how about smart cards? i have seen many new motherboards that have built in smart card readers. would this work the same? thanks,
    Etrik
    [ 02-08-2002: Message edited by: etrik ]
    "if everything is under control, you're not going fast enough!"
    Jul 1999
    Decorah, IA, USA
    Post
    Basically you get a CF to IDE adaptor, set it as your master, and install your OS on it. You won't notice much, if any, difference in POST time. Your boot time could improve dramatically, assuming your hard drive seek time (and not your processor speed) was previously your bottleneck. I'm not sure if they make smart card to IDE adaptors (not my department -- anyone else?), but if they do, it ought to work just fine. However, it probably wouldn't work with your mobo's built-in smart card reader, as that's likely not going to be on the IDE (or SCSI) bus.
    Jan 2001
    Adelaide, SA, Australia
    Post
    I remember reading on here that people didn't experience any speed difference with using CF media as opposed to a decent HDD. The only advantage to the CF, being durability.
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    May 2000
    NY
    Post
    I dunno how fast a harddrive can be... I guess it also depends on the processor you have too... but post-bios boots are pretty cool times. Besides durability (although these things blow after a few thousand writes/rewrites) it also is a little bit faster than a harddrive.
    There are smart card ide readers, but they are too expensive to justify the cheaper cost of smart cards. (www.mesanet.com)
    Free entrance to heaven? WOW! I DUN BELIEVE! JC!
    Mar 2001
    Perth, Australia
    Post
    hdd 22-40sec
    cf card 3-4sec
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Post
    From the reviews that Ive read, the compact flash can nearly max out the ide bus, so its a lot fast. its flaw in an windows environment is that it will wear out after a few hundered thousand read/write cycles, which seems like a lot, but wouldnt last very long as a scratch disk to windows. a lot of people use some custom installs of linux on a cf card.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
