Results 1 to 10 of 19
Thread: IDE Question / CD Drive Open/Close
    Nov 2004
    I found some documentation on the IDE pinprint but it didn't really have the answer i'm looking for.
    When utilizing WMP, Windows, or another Music Player to open/close a CD drive via Software/OS is there a specific wire number that is being triggered/grounded to tell the drive to open/close?
    The reason I ask is was thinking of having two CD drives in my IASCA SQ car next year. One is a Plextor 716AL for DVD, etc. and a Plextor Premium2 which will be behind a panel (or maybe just one drive behind a panel i'm not sure yet). The panel is rigged with a servo to open/close. If it's a certain wire/pin then I can just interrupt it with a relay/microcontroller to have the panel open first then the drive eject or something along those lines (after a very short delay). Closing is of course the opposite.
    Thanks!
    DIGItonium
    Guest
    How about rigging directly to the solder pads of the eject button?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by schreibers View Post
    Thanks!
    There is probably no postivie trigger for this, carried on a line. It is mostly likely sent as a data byte or bit, and the CD knows to eject or load the cd.
    Michael
    Nov 2004
    Quote Originally Posted by Wiredwrx View Post
    There is probably no postivie trigger for this, carried on a line. It is mostly likely sent as a data byte or bit, and the CD knows to eject or load the cd. l
    That's what I was afraid of.
    Still doable I just thought it would be cool to not have an physical eject 'button' to start the process of a cover panel opening then drive opening and vice versa. Working with two drives tho might get tricky as i'd only want one eject 'button' but the process is different for each drive.
    Thanks guys!
    DIGItonium
    Guest
    You can send a pulse to trigger the physical eject button. You will need to measure the impedance and voltages on each side of the eject button to determine the course of action. Check the change in voltage when you press the eject button. Your goal will be to raise or lower that voltage to trigger the eject function.
    You can use a small FET or transistor to accept the pulse and drive the eject pin high/low depending on the approach.
    Trial and error!
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    What about this, a hotkey mapped to it/them, via a USB gamepad button that is pressed as the cover or what not, opens?
    (CD Ejector program - freeware for lite version)
    http://www.nesoft.org/antilostcd.shtml
    (Hotkey assigning program - gnu)
    http://www.autohotkey.com/
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Mar 2002
    You could probably pulse a line on the LPT port (if the system has one) whenever the drive is soft-ejected to open the panel. If the panel opens too slow, you could write a simple program to kick the panel open, then soft-eject the disc tray.
    Also, there's the cheap OEM way, just have the panel be pushed out of the way by the CD tray itself. You might need to create a ramp on the bottom to keep the panel from catching on the CD tray.
    Sep 2005
    Oklahoma
    What about wireing a relay in to the tray drive motor, so that when the drive motor kicks in to eject the CD tray the relay trggers and the hidden panel opens. That way whether by soft or hard eject, the panel still opens.
    Just a thought.
    May 2005
    Mother Earth
    Sorry to raise up an old thread but maybe someone can help me..
    I want to use my eject button from my headunit to eject my cd. I mounted the slotload dvd drive in my headunit now eject is a problem.. there are 4 solder pads for the dvdrom switch and they are small attached to a wax board with thin wax cable
    the headunit has normal solder joints.
    Any special way or tips any one have for soldering it.
    Could the headunit short out my dvdrom
    Any advice is welcome.
    KIAs can have car pcs too..
    May 2005
    Mother Earth
    Okay since no replies i am adding pics maybe that will give someone a better idea of what i mean.
  1. How to relocate xbox dvd drive? IDE to usb?
    By osnola22 in forum Hardware Development
    Last Post: 06-26-2006, 11:40 AM
  2. Hacking Head Unit CD with CD/DVD-ROM slot load drive?
    By pktloss in forum Hardware Development
    Last Post: 03-25-2006, 09:42 PM
  3. Laptop Ide adapter on Laptop CD Drive
    By StangBoyCIC in forum General Hardware Discussion
    Last Post: 08-23-2004, 10:34 PM
  4. Slightly different hard drive mounting question
    By Tygur in forum General Hardware Discussion
    Last Post: 05-05-2002, 02:52 PM
  5. IDE Cable Length Question.
    By BeAR in forum General Hardware Discussion
    Last Post: 10-18-2001, 12:48 PM
