Results 1 to 8 of 8
Thread: Problem with IDE-to-USB adapter?
    Constant Bitrate urosbe's Avatar
    Mar 2005
    Hi!
    I have ordered IDE-to-USB adapter from CarTFT:
    I would like to have hot-swappable hard disc drive connected to USB, because I can remove it any time I want. But the problem is, that when I plug USB in, there is no new device detected. And of course, HDD has power (molex connector) and also USB adapter (floppy connector). USB adapter also has yellow LED turned on.
    Any ideas?
    http://www.cartft.com/catalog/item/?wm_item_id=381
    Regards!
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    May 2005
    Germany
    Hello,
    I have ordered the same adapter. My problem is after starting windows i can see my dvd drive and can work with it, but after a minute or so, the dvd drive is disconnected and I have to connect my drive by putting the usb connecter out and in.
    My drive is connected near the computer with a 0.5 meter usb-cable and is connected to the m2-atx.
    Could someone help?
    Ti-ejtsch
    Mar 2005
    I am also using M2-ATX and VIA EPIA, but the drive is not recognized even if I try on my desktop computer... when I plug in USB connector, nothing happens... no new devices in Device Manager, no new Drive or info about it in Disk Management. I also checked at bios post, when you can see how many USB are pluged in... and it looks like it doesn't recognize it. Maybe adapter doesn't work at all..
    CarDomain
    Mar 2006
    Colorado, but Canadian!
    Have you tried all the different ports? Also have you ever clicked "cancel" or "don't install this now" for a usb device on that board? I know some EPIA boards will self destruct if you do that and block out it's usb drivers until you reinstall the driver. I would getthe latest driver and update the usb. Then reboot and see what pops up. you have to be careful with the via boards. (I have one though, and I love it though!)
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    No, it's brand fresh install of Windows XP, never clicked "don't install" or something similar. And even if I try it on desktop computer, it is the same. I tried different ports... the one integrated on moterboard and on the front of the case...
    CarDomain
    Mar 2005
    I have to apologize, I figured out what I have done wrong. My HDD was without any jumpers, that means it was in "SLAVE" mode... when I put it to "MASTER" it was detected and everything works like it should!
    CarDomain
    May 2005
    Germany
    Hi,
    someone an idea for my problem?
    Ti-ejtsch
    Mar 2002
    Ti-ejtsch. it's most likely your power management settings for drives.
  1. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 03:30 PM
  2. comp won't boot with USB to IDE dvd rom plugged in
    By mjs3350 in forum General Hardware Discussion
    Last Post: 08-12-2006, 04:57 AM
  3. Problems with Usb to IDE Adapter
    By -zip- in forum General Hardware Discussion
    Last Post: 08-22-2005, 04:40 PM
  4. DVD-ROM with USB to IDE Adapter Problem
    By ret in forum Hardware Development
    Last Post: 08-08-2005, 10:20 AM
  5. Hibernate - Wireless USB Adapter problem
    By tejesh83 in forum Software & Software Development
    Last Post: 10-23-2003, 08:42 AM
