Results 1 to 7 of 7
Thread: via epia 800 - 512MB RAM
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    Question via epia 800 - 512MB RAM
    I recently bought a used via epia 800 since my plans for my carpc don't require any more power than that. The specs and instruction manual for the board clearly say that it supports up to 512MB RAM in either slot, for a total of 1GB. I made sure of that before I purchased. I pulled a single 512MB stick out of an older computer which originally had 1GB and installed in my new epia800. However, it only reports 256MB. It seems to be running fine other than that, but I can't seem to find a way to make it recognize the other 256MB available on the chip.
    Has anyone else run into this problem on this board?
    Also, I've looked for bios updates and haven't been able to find any for this particular board. If anyone has any suggestions it would be much appreciated.
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Sometimes, the actual ram chips need to be on both or one side of the board, try to find a chip that is opposite of what you have (and still 512mb). This is from my experience with older boards, but not VIA EPIA specifically.
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Jun 2006
    Texas
    Thanks for the suggestion. I'll try adding the second chip or swapping them around when I get home from work. It still seems weird, the memory works fine in the other computer and the documents say this board should be able to handle it just fine.
    Jun 2006
    Texas
    No go. Same problem with the other chip or with both chips. Except that with a gig installed I actually get 512 back. Does anyone know of any bios upgrades available for this motherboard?
    Aug 2006
    Try clearing the CMOS? Maybe some bad settings is causing the problem? Just a guess...
    Mar 2002
    Was the RAM from an Athlon system? If so, it's probably a chip density problem, as Athlon boards added support for higher-density chips that were cheaper. Most other systems will see half of RAM like this.
    How many chips are on the DIMM?
    Jun 2006
    Texas
    The ram is from an Athlon system. Each DIMM has 8 chips on either side for a total of 16 chips per DIMM. I've never heard that there was any difference between AMDs SDRAM and Intel's SDRAM before. But the explanation makes sense.
  1. Epia 800 or FV24 w/ P3 800
    By proph in forum General Hardware Discussion
    Last Post: 03-18-2006, 11:27 AM
  2. Replies: 6
    Last Post: 02-22-2006, 08:19 PM
  3. Replies: 2
    Last Post: 08-12-2005, 11:08 PM
  4. FS: Epia M10000, Opus Case, 512 ram, 30gb HD
    By Darek85 in forum Classified Archive
    Last Post: 07-26-2005, 12:29 PM
  5. FS: EPIA M10000 Mobo & 512Mb PC133 SDRAM (Brand-New).
    By buildfromscratc in forum Classified Archive
    Last Post: 09-20-2004, 09:32 AM
