Results 1 to 2 of 2
Thread: DAQ hardware supporting upto 12v
    Sep 2006
    Does anyone know any simple to use USB data aquisition hardware that supports car voltages? I am installing a carpc into a car without OBD and require some of the digital outputs displayed as dash lights to be viewed in the pc display. Analogue outputs such as engine temp or fuel may need to be veiwed too. Not too sure whether these analogue outputs a variable voltage or resistance though i'll get the simple digital outputs out of the war first.
    Any ideas ppl?
    Jul 2005
    I use a lot of these at work:
    http://www.measurementcomputing.com/...EKJX6D4WXU9L0C
    They accept up to 20Volts in differential mode G1.
    http://www.measurementcomputing.com/...08lsspecs.html
    As far as digital I/O use resistors for input voltage dividers (down to board range) and optocouplers or relays to raise TTL output to 12V:
    http://www.mikroe.com/en/books/picbook/7_04chapter.htm
  1. In-car PC controlling 12v outputs hardware/software ?!?
    By skinhead in forum General MP3Car Discussion
    Last Post: 07-18-2006, 01:26 PM
  2. -12V and -5V rails explained:
    By andrewb in forum Power Supplies
    Last Post: 03-19-2006, 11:52 AM
  3. How-To: Modifying the PW200
    By evandude in forum Power Supplies
    Last Post: 08-18-2005, 07:45 AM
  4. M1-ATX and heavy 12V rail
    By miki in forum Power Supplies
    Last Post: 05-13-2005, 08:18 AM
  5. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 01:33 PM
