Results 1 to 10 of 15
Thread: Small factor DVI/VGA cable?
    Low Bitrate dima237's Avatar
    Aug 2006
    Is there such thing as a small head dvi to vga or just dvi cable? I have a problem as my aopen mini pc is stuffed into a glovebox, but because it has dvi out and my screen is vga i have to use an adapter and because of that is sticks out quite a bit out the back of the glovebox. Because of that I cannot put the glovebox back properly (there are cracks because it does not sit properly).
    Aug 2006
    Ok, I think I found a solution, may try this
    http://www.flickr.com/photos/zapwiza...7594054134962/
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    you could do that.....
    i would suggest a short DVI extension so you can put it in a place where an DVI to VGA adapter will fit and then run a VGA extension to your screen. Taht should work. You can hack your own cable if you want and i bet it would be fun.... but i would probably get a pre made adapter... try ebay cuz believe it or not... its a good place to research and see if things exist
    Brown 2010
    Mar 2006
    NJ/RI
    oh if you have an adapter already then just get an extension....
    there should be a small form factor connection out there... or maybe a 90 degree angle adapter might help
    Brown 2010
    Aug 2006
    Thanks for reply. I'll look into it now
    Aug 2006
    Couldn't find any suitable solution in store and don't really want to wait for an internet order so decided to go the true DIY route.
    I have another question, do you guys know if Epoxy is conductive? I want to solder the wires to the pins and then cover it with epoxy to seal the deal or should I use something else?
    Dec 2002
    Hi
    Look lower down this page on slipperyskip's site... he's using a slimline VGA cable, looks good, don't know about pricing... Why don't thay all make them like this?
    Aug 2006
    problem with that is minipc is dvi out, so even if vga cable is small, i still have to use an adapter. DVI is the most important part because that's the part that's directly plugged in. The hack solution seems doable, VERY compact and is super cheap since i already have the adapter that i'm hacking. Just need to find the way to seal it properly so that it's insulated and protected from breakage.
    Mar 2006
    NJ/RI
    Umm as far as i know epoxy is not conductive....but what i suggest is you get what is called liquid electrical tape. Its like liquid plastic. Its a liquid that hardens to a soft nonconductive covering for the contacts. Then epoxy over that. That way no mater waht you are safe.
    You may want to consider an internet buy becase you probably will not find it in any store....
    I searched a bit myself...theres bound to be one out there...but i got distracted by a video splitter.....lol
    Hey i say doit yourself have a **** load of fun and if it doesnt work well then find something
    Brown 2010
    Aug 2006
    Thanks. What I'll try to do is let some epoxy harden and see if it conducts anything. Will post results if I have time.
  1. Extending your laptop's LCD cable: FAQ
    By Yuriy in forum LCD/Display
    Last Post: 11-25-2008, 03:06 PM
  2. Where can I buy film cable like this?
    By sstylos in forum General Hardware Discussion
    Last Post: 09-07-2006, 04:50 AM
  3. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  4. vga cable for lilliput
    By JaxPt in forum LCD/Display
    Last Post: 02-24-2005, 11:52 PM
  5. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
