Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: motherboard issues
    Aug 2005
    W. Bloomington, MN
    Question motherboard issues
    hi all,
    I have this problem with my pc. it seems like everyweek, my video driver fails on me. When i mean fails, i mean that when i start my car, on my monitor, it says no vga signal even though the vga is connected. what i usually do is to run in safe mode, uninstall the vga driver, and use the basic plug n play then restart windows and reinstall the driver. is there a reason why this is always happening? i am guessing it might be some power issues with my psu or a bad motherboard. any suggestions or has this happened to anyone before.? i am using a a-open i855 motherboard. i amm running a lilliput vga touchscreen @ 640*480 32bit @ 60hz? maybe using the wrong resolution? any suggestions on solving this issue? thanks
    _
    Mar 2004
    Little Elm, Texas
    are you running the monitor on a regulated power supply or just straight off of the battery?
    what PSU are you running?
    full specs on your set-up would be helpful.
    Jan Bennett
    Aug 2005
    W. Bloomington, MN
    Quote Originally Posted by RedGTiVR6 View Post
    i am running the monitor off the regulated power supply. everything runns from the regualted power supply so that when i start my car, everything comeso n the same time. i am using the opus psu.
    _
    Mar 2004
    Little Elm, Texas
    which opus? full specs please
    also, have you checked all of your connections to ensure that they are not coming lose in any possible way?
    Jan Bennett
    Aug 2005
    W. Bloomington, MN
    its an opus 150W i beleive..When u say full specs,
    i am running a-open board i855 mobo with 512mb and 160gb hdd
    lilliput 7in screen
    windows xp with roadrunner as my front end
    opus 150 dc-dc
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Are you using the most up to date driver for the card?
    Brown 2010
    Aug 2005
    W. Bloomington, MN
    Quote Originally Posted by Sidewalksalvage View Post
    yes i am..downloaded one from the intel website...based on my mobo
    Aug 2005
    W. Bloomington, MN
    any one have any suggestions? VGA screen crapped went out on when when i was on a date last nite...very shameful..need i say more?
    Aug 2005
    W. Bloomington, MN
    no suggestions? maybe get a new VGA carD?
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    Does your PC boot and when it gets into Windows the video ouput dies? OR from the time you turn it on it doesnt display anything?
    Each is caused by its own problems.
    If you are get output and go to boot into Windows and the video output dies it could be that some how your screen resolution is set too high and the monitor is no longer able to read the input. It can also be caused by faulty drivers but this usualy only happens if you have updated/installed new drivers lately.
    If you dont get any output at all it sounds to me like either your VGA card has come loose OR you board is failing to post due to memory problems or something like that. This would not be caused by driver issues simply because we are talking PRE-Windows load enviroment.
    Your card may also be damaged.
  1. Epia Motherboard GCS Capacitor Issues
    By rubicon in forum General Hardware Discussion
    Last Post: 08-05-2007, 12:36 PM
  2. Standby issues. Seriously confused here.
    By maxxell in forum General Hardware Discussion
    Last Post: 04-16-2005, 02:26 AM
  3. ATX Motherboard For sale
    By CJ8501 in forum Classified Archive
    Last Post: 03-18-2005, 11:29 PM
  4. motherboard grounding & psu doubts
    By RoyN in forum General Hardware Discussion
    Last Post: 02-25-2005, 02:26 PM
  5. For Sale: Intel D810EMO motherboard + Pentium 3 1GHz
    By Dexter in forum Classified Archive
    Last Post: 10-06-2003, 11:07 AM
