is the 28 or the 40 pin?
Anyone currently working with 18f2550 (or 4550)?
I need some hex for one to test it, just simple flash of leds on port B would be great. (I also have them on a and c)
small size etc no masterpiece....
C or asm wont do, need hex, I think my programmer is working against me so just need working tested hex.
20mhz crystal osc
my isp also seems to only work about once an hour, it must be hardware, but to say that I need tested hex etc.
Lez, more widely known as flez1966
肚子笑痛了
S60 Install
This will blink an LED on PortB.0
rename from .txt to .hex if needed.
肚子笑痛了
S60 Install
Yeah I avoid the 18F series for now. Everything I do I have been able to do with the 16F series, at least untill I want to go USB.
Let me know if I can help further.
肚子笑痛了
S60 Install
Guess what, still cant get it to work!
I've soldered wires on it and stuck them in the 18 pin socket, no use,
I have soldered them to the ISP connector, no use.
I tried this with a f88, worked, I soldered wires to a 877,
problematic but worked........
I think I'll just go on the web/ebay and see if I can buy a boot
loader programmed 2550 and dump this damn programmer..........
But........ if it can do a f88 and 877 its got to be working, so it must be the programmer software thats setting the programmer worng and/or a timing issue...
Oh how I hate this when I think of what I could have done with the day...
More than likely it's the programmer not setting the fuses correctly. I went through 2 programmers before I finally just purchased one due to them not setting fuses right.
What mhz are you trying to run it at?
Edit: Also is this with an external or internal osc?
肚子笑痛了
S60 Install
ucces !
hey my caps s has gone, damn keyoard hates me now!
Ok it was the POs software from sivava, tried winpic800, set it to willem, programmed and verified on the first go.
tried original software, would not even read it back correctly, back to winpic, 5 for 5 programs and verifys (with a 2550 soldered to isp)
plugged my project/proto board back in, nothing, found out I must not have anything connect to rb7 when programming, it had a 2k rsistor and an led, same as all the rb's, can leave the one on rb6, but not rb7.
so I have your code in, but nothing flashes, maybe its fuses like you say.
I'm on a 16mhz tin box crystal, so when I have had a cuppa, and watched a film to chill out, i'll come back top this...........
ditch the metal can osc, just go internal, the 2550 has a 8mhz internal osc, at least for testing purposes you can rule that out.
肚子笑痛了
S60 Install
Oooh thats good to know, one less part to buy when I build a few of these, I now have a working light flasher!
The programming problem was the software supplied with my programmer (a willem from sivava.com) was screwed, I tried winpic800, it worked first time and I have had a 10 for 10 program/verify result.
Then I tried to write my own led flasher, count 0 to 255 on the leds on port b, compile failed, seems I have some out of date include files, a bit of cut and paste fixed it but I dont think i2c has survived...not that I need it, at this stage...
So, thanks, I will try tomorro to shift my gsm-car-alarm over from the f88 to this pic so I can continue its development, I had ran out of IO pins and I also want the alarm to communicate back to the car PC.
inbuilt 8mhz you say...........
