Results 1 to 10 of 15
Thread: 2 Problems With Carputer
    May 2006
    Calgary, Alberta
    I don't normally push my car but my friend just bought a Honda and wanted see what the engine was like. So I put my car in 2nd gear and brought it almost to redline before shifting to 3rd. The first time I did it, the computer shut off and then booted up again. The second time, the sound cut out but the computer didn't turn off, and when I shifted to third, the sound came back on. So it seems like I'm having power issues with the alternator/battery/wiring setup. I was advised before I should look into upgrading these three but was never told to specifically, so do you think this would solve this issue? Do you think I'll have to before I set up my air ride?
    The second problem is starting the car in the mornings. The last 2 days have been the coldest since I got the computer and when I turn the car on in the morning, it says it couldn't load the media, then says there's a system error and to insert a boot disk and press any key to continue. Turning the car off and back on three times worked yesterday and today, though I'm not sure if the 3 was coincidence or if the car finally warmed up enough for the computer. It was about -11 celsius each time. For the rest of the day yesterday and today, it started fine after it warmed up outside.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Colorado, but Canadian!
    I forget which wires you used, but I remember drawing you a nice picture of your car exploding if you didn't upgrade the wires to thicker... I'd say that was specific. Yes upgrade the wires. Also do you have any other subs, big amps, microwave oven (hey you never know, it's Manheriano! ) plugged in?
    As for the disk boot error, I would say that your HD is not fully spun up and functional before the mobo says, "what the hell is plugged into me" and starts looking. Since the HD is not fully awake yet, it's all sleepy like, and misses the mobo's call. Then when it is awake, the mobo has already moved on to try other devices during POST. Now, unless one of those other devices has an OS, then it can't do anything because to the computer, there is no HD. Look in your bios. There might be an option for IDE delay or something similar. Set it to the maximum like 3 or 5 seconds, and that way the mobo will refrain from looking until that time has passed hopefully giving your HD the time required to take its coffee and get it's lazy *** working. This is strange though because you have a 2.5" drive, and only the crap bottom of the line ones can't stand -11C. Usually lower than that. I would be wary of the drive.
    Of course it could be other things but I advise you to check that first.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    LOL! thats great, I assume these are all very technical terms
    REBUILDING!!
    Mar 2006
    Quote Originally Posted by Dragonknell911 View Post
    Indeed.
    Gets the point accross without having to go into great technical detail.
    May 2006
    Calgary, Alberta
    haha sorry
    I have a 120 watt amplifier for my speakers and a 325 watt amplifier for the subwoofer. Wiring to the amps is 8 gauge to a distribution block and then 4 gauge from the block to the battery. Then 10 gauge from the computer to the battery. I remember your picture, the computer's been running fine since I took your advice.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Aug 2004
    how far is the computer from the distro block?
    REBUILDING!!
    Mar 2006
    Oh, and I forgot to mention, if there is no "delay" feature in the BIOS, then disable quick boot. That will slow it down when checking for memory. Then when it warms up a bit, you can re-enable quick boot and have fast tunes! Of course this will only work if you are cold booting. If you keep it in S3 or something, then you need to hack the HD to come on before the motherboard. SOmething like a timer circuit on the HD that doesn't care what the IDE input is so it spins up and waits for a signal before the mobo awakens.
    May 2006
    Calgary, Alberta
    The computer's not powered through the distribution block, it's powered straight from the battery.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    I was just thinking, that since you went into really high RPM's, won't your alternator give you a LOT of current. Because the power out is related to the magnetic field and the speed at which it changes, so lots of power should come out. Maybe too much came out, and your fuse was not low enough to pop, instead it just gave it all to the M2 which is a lottle dodgy to begin with and it just dumped it straighted into the board or maybe overloaded a cap or something causing it to malfunction until normal power again and it cleared itself. This a wildly huge guess, but it can't hurt!
    May 2006
    Calgary, Alberta
    I thought it was providing such a high current draw to the car that it couldn't give any to the computer. But yours sounds logical too.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  3. Problems turning my carputer on
    By nappyjim in forum Power Supplies
    Last Post: 05-04-2005, 10:21 PM
  4. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  5. Carputer in '03 Vette - plz suggest
    By slushieken in forum Newbie
    Last Post: 04-19-2004, 12:15 PM
