Results 1 to 6 of 6
Thread: Alternative to sound card
    Aug 1999
    IL
    Post Alternative to sound card
    Here is a device for $59 dollars that is originally designed for mini-disk recording but would work great in a car mp3 setup instead of a soundcard. This should eliminate some of the small buzz/noise that some people are still having because of the soundcard being inside the computer and open to various interference.
    MD-Port AN1
    [This message has been edited by xa0s (edited 11-19-2000).]
    Oct 2000
    Melbourne, Australia
    Post
    Nice idea, but I think this thing is basically a converter to allow MP3s to be recorded onto mini disk which uses a different form of audio compression.
    The two arent compatible unfortunately.
    Aug 1999
    IL
    Post
    I believe it is basically an outboard DAC which converts to analog source. They also have a model that converts to TOSLINK for input from pure digital source.
    Nov 1999
    California
    Post
    So would you not need a sound card for this to work? It could keep the height of the case down a bit.
    -Shaxs
    Car
    1964 Ford Falcon powered by a 1993 Mustang 5.0 EFI, AOD transmission, with disc brakes up front and more mechanical goodies
    The Player
    Gone! Soon goign to repalce the screen based system i HAD with an iPod. http://mp3falcon.crazyshaxs.com
    Aug 1999
    IL
    Post
    No, you would not need a soundcard. Just a USB port!
    Nov 1999
    California
    Post
    Intereasting....thats what I thought. This could help cut down the height of the mp3 box dramatically. Especailly if you buy an agp riser card for the vid card. I found out the agp riser card with right angle is around 25 dollars.
    Car
    The Player
