my question is.. why do you want to shut off the power at all?
I have all of my devices plugged in and they dont shut off when the car/pc are off but that doesnt bother anything does it?
Hey Folks,
So I got the answer back from Aopen that there's no way I can have the USB bus powered off during standby. This forces me to the old way of cutting open the USB cable, cutting the +5v and ground lines on the USB cable, and splicing these into the respective lines on the molex connectors on the mobo so the USB device receives power only when the PC is on. Questions on this:
1. Can I connect 3 seperate USB cords to the same spot of a single molex connector? i.e. I have 3 USB cords that I need to do this with (some devices are not happy being on a hub, otherwise it'd be one cord) and I'm wondering if I need to pick 3 seperate molex connectors or sections on molex connectors to power these correctly? Can all 3 be spliced into one spot on the molex lines?
2. If I can do all into one spot, I'd like to do this via some type of connector, do such things exist? Example: the molex cables terminate on a connector that has inputs for 3 other connectors...something like a 3-to-1 AC power outlet.
4. Is there a better way to do all of this?
TIA,
Per
molex connector = the connector that supplies power to your standard IDE hard drives. These are a great source for tapping power if you want something only on when the PC is on. The 4 wires supply +12v, +5v, and two grounds (yellow, red, black, black). These only receive power when the PC is turned on. So - you connect the power and ground cables from your USB cable that leads back to your device/hub (it has 4 wires, the other 2 are for data) and splice these into the red and black wires on the molex connector.
perhaps wording was poor..i mean to say tapping the wires that lead to the molex connector (although getting a male/female pairing on the connector itself is also possible).
good info at: http://www.playtool.com/pages/psucon...tml#peripheral
Dude, I know what Molex connectors are. They come from the PS, NOT FROM THE MB. That was the confusing part. (Don't take this the wrong way)
Yes, you can tap into a single molex to power your USB devices. USB is specd at 500ma per device. 3 devices will use 1.5 amps. That connector is easily capable of that. The wires should be at least 18 gauge, and preferable 16 gauge, if you are gonna run 5 or 6 feet or less.
Michael
P.S. That link is great, I will try and get them to add it to a FAQ or something.
i figured it was my wording..typing in a hurry, sorry ;-)
what if i have 2 devices and one hub? the hub has 4 devices on it: touchscreen, OBD-II cable, RF keyboard, and DVD player. The DVD player and the hub have external power being supplied by the second output of the Carnetix 1900....think I'm still good to go?
I am not very familiar with the carnetix, but maybe you can power all the USB stuff off the carnetix.
In any event, the connector is good for, I think I read, 14 amps. You should be fine, as long as your cable is sufficient to handle the amperage. I would not go smaller gauge then 16, perhaps 14 to be ont he safe side, and don't run it too long. EDIT: I MEAND LENGTH WISE, not time wise.
Michael
