Results 1 to 4 of 4
Thread: Cold weather, chassis cooling fan problem
    Aug 2004
    I run a Compaq MB and the MB requires a chassis cooling fan to be connected directly to the MB for it to boot. When it gets cold out, the fan is slow to start spinning, the motherboard can sense that and doesn't boot, if I leave it on for a minute or 2 then restart it, the fan spins well enough for the PC to boot. I'm either looking for a fan that's better suited to deal with low temps or a way to fool the PC into thinking the fan is still spinning when it's not, and will still allow it to spin when it warms up. Any suggestions?
    Elsewhere
    Replace the fan. They're not expensive.
    If you're running Compaw hardware, that means it's not exactly new.
    How about the Wiki?
    Aug 2004
    Quote Originally Posted by DarquePervert View Post
    the fan didn't come with se mobo, it's a stadalone fan, and it's nearly brand new. I probably will replace the fan, but with what? Any luck with any specific fans in cold weather?
    Elsewhere
    For cold weather, I'd think that a ball-bearing (as opposed to bushings) would perform better, but I'm certainly not the expert.
    How about the Wiki?
  1. speaker magnet touching chassis - problem?
    By Jamez_Warner in forum Car Audio
    Last Post: 05-16-2004, 05:59 AM
  2. I can't connect my hard drives + fan problem
    By haisook in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:42 PM
  3. COLD problem ? rebooting
    By BOND007BE in forum General Hardware Discussion
    Last Post: 12-16-2003, 02:54 AM
  4. UK Weather - Cold & Damp - Poss. Probs ?
    By CivicDisturbance in forum Newbie
    Last Post: 11-26-2003, 03:12 PM
  5. Hard Drives in cold weather?
    By nicksmurf in forum General Hardware Discussion
    Last Post: 11-17-2000, 11:44 AM
