Results 1 to 7 of 7
Thread: Cellular WIFI Antenna?
    Low Bitrate scott011422's Avatar
    Sep 2003
    Genoa, Il
    Hey all, My truck has a factory ONStar antenna. Which is basicly a cellular antenna. With this work with my WIFI if I connect it? I was able to use my factory XM antenna on my PCR buy just tracing back and a little soldering, But am unsure if that type of antenna in general will work........
    It's not what you buy............It's what you build
    Elsewhere
    No.
    The antennas are tuned differently.
    There's a Hirschmann GPS2400 in the store here that does GPS, cellphone and wiFi: http://store.mp3car.com/ProductDetai...Code=COM%2D008
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    and it works quite well.
    Just be aware that you will need a GPS reciever to use the GPS.
    Jan Bennett
    Sep 2003
    Genoa, Il
    Yea, That be great, but then I have to ADD another antenna too bad the bottom isn't slightly curved!.....Bummer
    _
    Mar 2004
    Little Elm, Texas
    well, you can't adapt a cellular antenna to be a wifi antenna as far as I know, so you're going to have to add another antenna anyways, that one includes cellular, so you can remove the one youhave now and plug it into this one
    Jan Bennett
    Sep 2003
    Genoa, Il
    Thats the thing, It just sits there now! I don't use it. It looks alot like the one your showing me, But mine has a slight curve to it. And I don't really have the room for a flat mounting.......Sucks..........
    _
    Mar 2004
    Little Elm, Texas
    it's not very big at all...possibly...at most 2" wide x 3" long? maybe I can measure mine tonight.
    Jan Bennett
  1. Recommend WiFi card and Antenna?
    By DaveB in forum Wireless Communications
    Last Post: 01-25-2006, 12:04 AM
  2. Adding external wifi antenna to ibook
    By daj100 in forum MacCar
    Last Post: 12-12-2005, 03:17 PM
  3. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 07:43 PM
  4. WiFi Antenna w/ 1W amp through Tint.
    By SKiTLz in forum Wireless Communications
    Last Post: 11-10-2005, 11:49 PM
  5. Through glass mount wifi antenna
    By n8scstm in forum General Hardware Discussion
    Last Post: 01-31-2005, 09:11 PM
