Results 11 to 20 of 23
Thread: LCD cable using RJ-45 network cable?
  1. #11
    Nov 2006
    Northamptonshire (UK)
    as you say cat5/6 ethernet cabe is the way to go in that case, as someone has already said in this post probably best to use screened cable and connect the screening at bouth ends to ground. this hsould be fairly easy to do and good luck with your install! will you be posting in in the project logs?
  2. #12
    Mar 2005
    Make sure you're careful with the shielded cable.. if its bent wrong/too hard/whatever, you could wind up damaging the wires.
  3. #13
    Low Bitrate com2soft's Avatar
    Sep 2006
    Quote Originally Posted by screwc149 View Post
    yes, plan to buy its case off ebay. not cheap 175+50. they told me will give me shielded rj45 so i save the trouble. will see how it work out.
  4. #14
    Sep 2006
    Quote Originally Posted by darthness View Post
    noted. thanks!
  5. #15
    Nov 2006
    Well keep us updated as im sure its not just we who's inetersted in se'ing how this turnsout.
  6. #16
    Sep 2006
    arrived and i fitted in a M10000. see pic.
  7. #17
    Nov 2006
    That looks great, how are the results when hooked up to a screen? where did you buy your case from?
  8. #18
    Sep 2006
    it worked o.k. for my liliput 7" touchscreen. i don't notice the difference when switch to a vga cable. here is the place
    P.S. the 5m rj45 is too long. i think i will cut it to fit my car.
  9. #19
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    Could you post some more close up photos of the RJ45 connector board?
    Jarrod - Holden VX S!
  10. #20
    Sep 2006
    Quote Originally Posted by Jarrod View Post
    the rj45 connectors are marked #1,#2,#3 on board and on pcb go to pin insert flat rubber connector - with connectors to insert into the mobo. It require a power plug (from PSU) to power up the 12V out rail. two USB on the pcb (one is drop inside the case so a Bluetooth stick will insert and half way into the case leaving only the tail part outside the case). two USB goes to the head unit (i don't get it 4pin x 2=8) but it is true i plug into the onboard 2 USBs
  1. AutoVision LCD cable?
    By the thomas in forum LCD/Display
    Last Post: 10-07-2007, 10:22 PM
  2. network cable to RCA video
    By CayenneRedV6 in forum LCD/Display
    Last Post: 02-23-2006, 10:00 PM
  3. LCD cable won't work
    By dudah85 in forum General Hardware Discussion
    Last Post: 07-18-2001, 10:35 AM
  4. What cable for the LCD to the trunk?
    Last Post: 05-09-2001, 04:36 PM
  5. lcd cable length extension?
    By newbie in forum General Hardware Discussion
    Last Post: 03-13-2000, 06:31 PM
